Thread: 2004 comp g
Results 1 to 14 of 14
  1. #1 2004 comp g
    Jan 2018
    US
    Reduce engine power and low fuel light after putting 10 gallons of fuel in the car and blowing the fuel pump fuse. Is this cause the map or maf sensor be going out?
    Sent from my Pixel 2 XL using Tapatalk
  2. #2 Re: 2004 comp g
    REP triggers an engine code.
    Pull the code and diag the problem from there. The MAF and MAP alone won't blow a fuel pump fuse.
  3. #3 Re: 2004 comp g
    Jan 2018
    US
    I just went and bought a engine scan tool and it pulled up a barometric pressure sensor performance code and throttle body code. I'm just wanting to know what is a barometric pressure sensor is bud
  4. #4 Re: 2004 comp g
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by pickettjarred View Post
    Usually when you see the barometric code, it's telling you that you have a vacuum leak or other issue. If you can read the map sensor values, you can verify this, or you can observe the voltage with a multimeter between 0 and 5v. What throttle body code are you referring to?
  5. #5 Re: 2004 comp g
    Aug 2017
    Raytown, MO
    I would either try the vacuum leak test with carb cleaner, propane, or best case, see my thread on vacuum smoke leak detector in the how -to section. My money is on vacuum leak. How's it run at idle? And can you read short term and long term fuel trims. Positive ltft would indicate vacuum leak.
    Have you checked the fuel pressure key in, engine off and when running?
  6. #6 Re: 2004 comp g
    Jan 2018
    US
    Quote Originally Posted by wstefan20 View Post
    P0068 is the code and I got a p0069 code also
  7. #7 Re: 2004 comp g
    Jan 2018
    US
    And it runs fine. After a minute of it running it'll drop the fuel level to empty and continue to run like a charm. It had a reduce engine power light come on my guage and it'll loose everything if I drive a quarter of a mile
  8. #8 Re: 2004 comp g
    Aug 2017
    Raytown, MO
    I think you might have two separate problems. The codes you have usually indicate a vacuum leak, along with the reduced power, and the gauge sounds like a bad fuel level sensor which could be why the engine is turning off, but I don't know enough about the newer gps computer system to say for sure. Just to be safe, I'd still rent the fuel pressure gauge (easiest thing in the world, there's a Schrader valve where you hook the gauge up) and take a reading with key on engine off, running, and throttle snap just to rule out the fuel pump. I'll see if I can't find a how to diag for that issue.
    As for the map codes, I'd check for vacuum leaks using the methods in my prior posts. There's good you tube videos on all the methods.
  9. #9 Re: 2004 comp g
    Aug 2017
    Raytown, MO
    So the gauge will read empty when the gauge ground is disconnected. Again, I'd test the fuel pressure. Not sure if there's an easy way to test the sending unit on the 04+ models without dropping the tank, but there's lots of videos on how to test this and your fuel pump. Hopefully the 04+ guys chime in on that. Without seeing it though, my gut feeling is that there is either a bad section of wire, corrosion, and most likely, the ground for the fuel pump. I'd start by checking the pump ground for corrosion.
  10. #10 Re: 2004 comp g
    Jan 2018
    US
    I appreciate all the info bud. I'm about to the point of buying a donor motor and building the thing.
  11. #11 Re: 2004 comp g
    Aug 2017
    Raytown, MO
    I understand troubleshooting can be annoying, but If this is a fuel pump or grounding issue, you'll be throwing your money away because you'll have the same issue even if you went back in time and grabbed a brand new engine off the assembly line. Trust me, I used to be a parts swapper, and I've wasted a lot of money and time versus me not taking the time to figure the real problem out. I hope I'm not coming off too harsh, my only intention is to help you not make the mistakes i have. In the end, it's your choice, and I wish you luck either way! We're always here when you need help.
  12. #12 Re: 2004 comp g
    Jan 2018
    US
    I'm just worried this motor is about to blow up. I've had a lot of problems with it and just tired of it. plus side I'm wanting to go with a turbo application and to make the next motor last I'm wanting to build it.
  13. #13 Re: 2004 comp g
    May 2016
    Burns City, Indiana
    Ok so lets first diagnose the car. There is a need to verify the fuel system. As these are returnless always verify everything. As stated you could throw brand new off the line wngine in and if parts hanging on it are junk your pissing in the wind.
    P0068 means that the Powertrain Control Module (PCM) has detected an excessive degree of variation in the input voltage signal from the throttle position sensor (TPS) as compared with voltage input signals from the mass air flow (MAF) sensor and the manifold air pressure (MAP) sensor. The PCM reads and calculates these individual engine drivability sensor signals and then compares them to help develop fuel delivery and ignition timing strategy. The PCM also utilizes this information to ensure that the fuel-to-air ratio remains constant, controllable, and within acceptable limitations. If the detected voltage values of these three sensors (triangulated) fail to coincide with programmed desired parameters, over a specific period of time or engine revolutions, a diagnostic trouble code will be stored and a malfunction indicator lamp will likely be illuminated.The most frequent contributors to this code being set are large vacuum leaks as a result of cracked, broken, or otherwise collapsed vacuum lines and hoses. Other sources of vacuum leaks include defective intake and throttle body gaskets, EGR valve and gasket malfunctions, and vacuum operated component (brake boosters, etc.) defects. Other possible causes could include a cracked or disconnected air intake pipe, clogged air filter, a faulty TPS, MAF, and/or MAP sensor, or a defective PCM.
    P0069 The manifold absolute pressure (MAP) sensor is used to measure engine load. The powertrain control module (PCM) sends the MAP sensor a reference voltage and the sensor varies the voltage according to manifold vacuum. The PCM then uses this information to adjust ignition timing and fuel delivery.
    Vacuum and pressure are inversely proportional (when vacuum goes up, pressure goes down). Because of this, the MAP sensor is able to measure the pressure in the intake manifold to gauge vacuum. Manifold vacuum is a good indicator of engine load. With the engine off, manifold pressure and atmospheric (barometric) pressure are the same. With the engine running, the movement of the pistons and restriction of the throttle plates create vacuum (reduce pressure). When the engine is under heavy load at wide open throttle (WOT), vacuum is nearly zero. At this time, engine pressure and atmospheric pressure are almost the same.
    Depending on the elevation, barometric pressure is usually between 28 to 31 inches of mercury (Hg). By comparison, engine vacuum at sea level is between 17-22 in-Hg. This drops approximately 1 in-Hg for every 1000 ft. of elevation. On some vehicles, when the engine is first started, the PCM looks at the MAP sensor to determine barometric pressure. There are other vehicles, however, that use a dedicated BARO sensor. Others still use a combination BMAP sensor.
    There are two types of MAP sensors: analog and frequency. The analog type uses a diaphragm and is connected to the intake manifold by a vacuum line. The sensor monitors the movement of the diaphragm and sends a corresponding analog signal back to the PCM. This type of sensor will have three wires: reference, signal and ground. The other type of MAP sensor is the digital, or frequency type, which produces a digital voltage signal instead of an analog signal.
    analog-map-sensor
    A cut away of an analog MAP sensor
    (Courtesy: autozone.com)
    As was mentioned, some vehicles use an independent BARO sensor. These devices are designed to measure only barometric pressure. The BARO sensor is similar to the MAP sensor in design but is more sensitive to changes in atmospheric pressure.
    The code P0069 stands for manifold pressure/barometric pressure correlation. The PCM compares BARO sensor and MAP readings at idle. If the difference between the two is greater than specified, the PCM will set a diagnostic trouble code (DTC).
    MAP sensor circuit problem
    BARO sensor circuit problem
    Faulty MAP sensor
    Faulty BARO sensor
    Faulty PCM
  14. #14 Re: 2004 comp g
    did you do work to it before all this started?
    like vac lines redone maybe? the back of the sc is two map sensors, well one, the other is a baro sensor, both look the same. one gets a vac line, the other does not, so if you mixed that line up, that could be the one code.
    you have a hard line from the intake tube to the blower's pcv port, make sure thats in place on both ends.
  1. New 2004 GTP Comp G!
    By FlightSergeantRose in forum Introductions/Noob Questions
    Last Post: 04-23-2017, 10:46 PM
  2. New here, 2004 Comp G
    By PaintChips97 in forum Introductions/Noob Questions
    Last Post: 04-10-2015, 04:21 PM
  3. new guy with a 2004 comp g
    By oh05ext in forum Introductions/Noob Questions
    Last Post: 03-17-2014, 07:57 PM
  4. 2004 gtp comp g
    By 90cobraclone in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2012, 10:39 AM
  5. 2004 Comp G
    By 04BlackComp_G in forum For Sale - Vehicles
    Last Post: 02-04-2012, 11:17 PM
