I could use a little guidance on the proper steps to starting an engine after top rebuild.
Things I replaced were: timing chain, dampener, crank and cam sensor, all gaskets, water pump, 90# springs, ported heads and had a valve job done, Transmission and all that goes with these things.
I filled all fluids and cranked the engine without starting it a few cranks. I then started it for a few seconds and shut it down because it didn't sound good. I started it up again for a couple more seconds and sounded the same. It's dark out so I called it a night.
Is there anything I need to do to get the crank and cam sensors learned other than just letting it run? Anything else I should do before letting it run longer? I did notice that the second time I started it the low oil pressure light came on before I shut it down. Any insight appreciated!
