Post the tune file as well.
Remove the 1 bar map channel and replace it with the 2 bar map channel so you can read boost in the scanner. I'm assuming you are running a 2 bar map. Something seems off if your wideband is correct. You are commanding 12's but your wideband it always in the 13's at WOT.
