Thread: valve seals for modded heads
Results 1 to 7 of 7
  1. #1 valve seals for modded heads
    Nov 2011
    kaukauna
    I had my engine guy machine .100 off the valve guide boss on the heads for retainer clearance due to ZZP XP cam. I bought ZZPs viton valve seals and gave them to the builder to install. He said they would not fit over the valve guide boss. He installed valve seals he found on his own. Now 20k later the engine is burning oil. I took off front valve cover and found a seal that has tore and is now at the top off the valve stem. My question is this. Did he take too much off the boss and now the taper of it is too wide for a seal to slip over? Is there other seal options for this?
  2. #2 Re: valve seals for modded heads
    Nov 2011
    kaukauna
    valve seals for modded heads Attached Images
  3. #3 Re: valve seals for modded heads
    Nov 2011
    kaukauna
  4. #4 Re: valve seals for modded heads
    May 2017
    Dirtyzville, Mizzery
    I ran Viton seals on heads that were milled .100". No oil burning issue. Sounds like an install error on his part.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  5. #5 Re: valve seals for modded heads
    Nov 2011
    kaukauna
    If ya want it done right so it yourself......I'll be trying new seals, with the heads on. Not fun.
  6. #6 Re: valve seals for modded heads
    Nov 2011
    NY
    Intense has the modded seals as well... Not a bad job, but PITA because you shouldn't need to be doing it.
    I would take one intake and one exhaust spring off and Mic the valve stem (o.d.) and talk to intense, make sure the i.d. Of the seal is good to go...
  7. #7 Re: valve seals for modded heads
    May 2008
    Schuyler, NE
    I've done the .1" off the valve guides and not had a problem with getting viton seals to work. They do have a problem with popping off though. Prj sold tighter fitting seals that stayed on better.
  1. Bad valve seals?
    By Russosaur in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2017, 12:22 PM
  2. Valve Seals and Modded Retainers for s1X
    By Jomamma in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2015, 12:38 AM
  3. Are these valve seals the same?
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2015, 05:33 PM
  4. Valve stem seals
    By bachert24 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2015, 03:45 PM
  5. Correct valve stem seals?
    By 88formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2012, 02:48 PM
