Thread: Tire pressure light
Results 1 to 11 of 11
  1. #1 Tire pressure light
    Feb 2017
    Puyallup
    I brand new tires and my tire pressure light is still on, what is the causec
  2. #2 Re: Tire pressure light
    SWPA
    Probably a dead sensor
  3. #3 Re: Tire pressure light
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Could also just need to reset the system. 97-03 i think had the button below the steering wheel on the right.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  4. #4 Re: Tire pressure light
    GTP Level Member
    Jun 2016
    Cleveland ohio
    What year. Give us more details. It varies.
    97-03 like said has a reset button. 04+ had a spot in the DIC to reset the light. I believe 06+ has the tpms system.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  5. #5 Re: Tire pressure light
    Feb 2017
    Puyallup
    1997 Pontiac Grand Prix GTP 3800 series
  6. #6 Re: Tire pressure light
    Feb 2017
    Puyallup
    Quote Originally Posted by rickisrad View Post
    1997 Pontiac Grand Prix GTP 3800 series 2 door
  7. #7 Re: Tire pressure light
    GTP Level Member
    Jun 2016
    Cleveland ohio
    yes look under the dash there should be a yellow button to reset. Make sure that all the tires are filled to factory spec or all the same pressure. If I remember correctly on my 97, key in the on position and hold the button for about 30 seconds and the light should go off.
  8. #8 Re: Tire pressure light
    Feb 2017
    Puyallup
    Thank u
  9. #9 Re: Tire pressure light
    Feb 2017
    Puyallup
    complete thank u so much
  10. #10 Re: Tire pressure light
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by ponntiacgirls View Post
    You are welcome!
  11. #11 Re: Tire pressure light
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    You left on the chat you were needing some parts and things.
    I don't remember exactly what you were looking for, but someone suggested rockauto. There were some interior and other minor pieces listed maybe? Cupholders and etc can be found at a junk yard.
  1. My abs and check tire pressure light on
    By Jonarin in forum General Tech Discussion
    Last Post: 02-03-2015, 07:25 PM
  2. tire pressure light
    By Dennis Reeder in forum General Grand Prix Discussion
    Last Post: 05-01-2012, 07:15 AM
  3. ABS and check tire pressure light on
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 02:12 PM
  4. tire pressure light
    By ibanez0110 in forum Brakes/Suspension/Chassis
    Last Post: 12-06-2008, 03:01 AM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
