I brand new tires and my tire pressure light is still on, what is the causec
Could also just need to reset the system. 97-03 i think had the button below the steering wheel on the right.
Sent from my SM-G920P using Tapatalk
What year. Give us more details. It varies.
97-03 like said has a reset button. 04+ had a spot in the DIC to reset the light. I believe 06+ has the tpms system.
1997 Pontiac Grand Prix GTP 3800 series
yes look under the dash there should be a yellow button to reset. Make sure that all the tires are filled to factory spec or all the same pressure. If I remember correctly on my 97, key in the on position and hold the button for about 30 seconds and the light should go off.
Thank u
You left on the chat you were needing some parts and things.
I don't remember exactly what you were looking for, but someone suggested rockauto. There were some interior and other minor pieces listed maybe? Cupholders and etc can be found at a junk yard.
