Thread: Intercooler pump flow testing
Results 1 to 12 of 12
  1. #1 Intercooler pump flow testing
    Kemmerer, Wyoming
    I've been doing some research on intercooler pumps and have found that one pumps flows more than many others while costing less than those others.
    The Stewart Components EMP 29/32 can be found on Ebay for about 300 bucks. I realize that is a lot more than the Bosch pump many people use, however this pump outperforms the Bosch by a substantial amount.
    Here is a test that Lingenfelter performed on a bunch of different pumps.
    http://www.lingenfelter.com/forum_li...esting-results
  2. #2 Re: Intercooler pump flow testing
    On a car like these with small intercooler core and small heat exchanger size you don't need something that flows that much fluid. They are great pumps but would be pretty overkill if you ask me.
  3. #3 Re: Intercooler pump flow testing
    Kemmerer, Wyoming
    I've been thinking about putting together another intercooler, only this time with an ice box in the trunk and a heat exchanger in the front. with all the extra length of hose, I would like to have a better pump.
  4. #4 Re: Intercooler pump flow testing
    Albuquerque, NM
    Off topic. Can someone tell me how to post? Please, I need help from square one.
  5. #5 Re: Intercooler pump flow testing
    Kemmerer, Wyoming
    obviously you figured it out, and have posted 8 times already
  6. #6 Re: Intercooler pump flow testing
    hangover park IL
    you would do better to modify the intercooler core and plates to make it a single pass core instead of dual pass.
    ~James~ Psychotic Gearhead
  7. #7 Re: Intercooler pump flow testing
    Kemmerer, Wyoming
    would the end tanks have to be tig welded or could they be silver soldered? that thought did occur to me but I have no practical experience in this type of thing.
  8. #8 Re: Intercooler pump flow testing
    hangover park IL
    Tig
    Keep in mind that the zzp plates do not allow you to do this. You need the W Body store intercooler plates that are solid aluminum to machine the passages for the outlet tubes towards the tb.
    The zzp plates have large open internal areas for their PCV Passage
  9. #9 Re: Intercooler pump flow testing
    hangover park IL
    The 442 thread should have information on ours as well as pics
  10. #10 Re: Intercooler pump flow testing
    May 2008
    Schuyler, NE
    There's a guy in Wichita that swears by these pumps. He said you can get them for around $250 on ebay.
  11. #11 Re: Intercooler pump flow testing
    May 2008
    Schuyler, NE
    Minus our core problems, the math does show that a nice gain could happen from a decent pump. I doubt you'd see much of a difference on the dyno though.
  12. #12 Re: Intercooler pump flow testing
    Kemmerer, Wyoming
    there would probably be a big difference with an ice tank and a single pass intercooler core with larger intercooler lines and a good pump.
  1. Fuel pump testing
    By Deviq in forum General Tech Discussion
    Last Post: 06-24-2012, 11:55 AM
  2. fuel pump flow
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2011, 10:47 AM
  3. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
