Thread: boost problems?
Results 1 to 2 of 2
  1. #1 boost problems?
    Jul 2015
    indianapolis
    hey guys, recently ive been replacing vac lines and tees on my 98 gtp and i noticed when i was out a did a 1st gear wot pull and i was only reading 5-6 bars on the dic display and from what ive read its supposed to be all bars on wot. i unhooked the boost bypass solenoid too see if that was it because i know people bypass it aand there was no change it was the same smh and i just replaced the bypass actuator because of a broken barb on one end of it so now im at a loss on what to check and or replace next? any advice or anything would be appreciated thanks alot!
  2. #2 Re: boost problems?
    Getting an actual gauge to read boost is better than trusting a lego brick on the dash.
    Either get a real boost gauge or a scan tool that can read MAP KPA. You'll want to see a MAP KPA of around 150 for 7lb of boost, which is close to factory. Figure 140-150kpa is a good spot on a stock vehicle making 6-7lb of boost.
    If one of those shows it's low, then either you still have a vacuum/boost leak, the BBV needs adjustment or the rotor coating is completely gone and causing a slight loss in boost pressure.
  1. Boost problems
    By BLACKanREDgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2017, 06:54 PM
  2. Boost problems
    By BLACKanREDgtp in forum General Tech Discussion
    Last Post: 02-20-2017, 11:16 PM
  3. Boost problems
    Last Post: 07-10-2015, 09:28 AM
  4. boost gauge problems
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 12:21 AM
  5. 99 Gtp boost problems
    By justrunningagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 05:40 PM
