I've been out of the wbody for a while but cant recall if/when porting a gen 3 outlet if it generally increases boost at all? I had thought not, since it's merely to lower the amount of heat due to the sharp edges in the outlet. the story here is that im helping out a local member where when I tuned his car it was on a stock blower running 7-8psi. before I sold my gtp, I swapped blowers with his so he was able to get a ported gen 3 blower. I believe the inlet's also been opened up a bit. he's now reporting via ls1m scanner that it's running on average 9.5psi and max of 3* of KR with 1-2* constantly on stock pulley. he also has u-bend delete but I believe stock manifolds still. for the time being, he's running with the BBV unplugged so boost is cut at 3-4psi safely. thanks for reading.
