Thread: sputters under full throttle
Results 1 to 4 of 4
  1. #1 sputters under full throttle
    Jul 2016
    Algonquin
    ok. im lost on this one. no engine light. runs fine when driving normal. however. under full throttle it sputters after 5k rpm. all 3 coils are sparking no problem so i dont think its icm or coils. ive herd a clogged up cat could cause this but i have a 3in catless down pipe. i put new ngk tr6 plugs on it about 8k miles ago. has anyone ever had this issue before? i have new plugs and wires on there way. if its not that what else could it be?
  2. #2 Re: sputters under full throttle
    Start with the plugs, one could be cracked.
    Or maybe you are losing fuel pressure at high rpm.
  3. #3 Re: sputters under full throttle
    Apr 2017
    Ontario
    Did you happen to put pre mixed gas in your tank......that can cause it to do that..............
    99 GTP: DIY FWI-3in CDP-rez del-plog-napa spark wires COME ON WILL I WANT MY TUNE!!!!!!<3 Intercooling next
    <3 PROUDLY Canadian / PROUDLY Austrian "Look, Gasoline's perfectly safe.....until you introduce ol Orange."
  4. #4 Re: sputters under full throttle
    GTP Level Member
    Jun 2016
    Cleveland ohio
    If you have access to a scanner look at the individual cylinder misfire count. That will give you an idea of where to look. if you see high misfires on a specific cylinder swap the coil with one of the other ones to see if the misfire follows. also scan for knock
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  1. 04 GTP Sputters When Under Full Throttle
    By loudandlow in forum Engine
    Last Post: 04-22-2015, 08:42 PM
  2. Stutter under full throttle?
    By Stevenhendrixjr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2013, 05:18 PM
  3. Full Throttle Hiccup
    By BigKev2403 in forum General Grand Prix Discussion
    Last Post: 05-09-2013, 07:29 AM
  4. Hitch when under full throttle
    By rvnwlf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2012, 08:22 PM
  5. KR under full throttle
    By Twist in forum General Tech Discussion
    Last Post: 04-16-2012, 12:55 AM
