Thread: High knock-runs like crap.
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah the trans has been replaced. I will check the sensors, do a case learn and report back tomorrow with the findings.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #42 Re: High knock-runs like crap.
    Mar 2017
    Internet
    The rear knock sensor has a pigtail on it that connects into the main harness and clips at that connection to the back of the ps pump. it's almost a given that the pump comes off to do a trans. Not required if you know what your'doing..but it usually seems needed to most people. Also when the trans goes back in, it's easy to bump that rear connector at the sensor.
  3. #43 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Man this is getting frustrating!!!
    I have both an Aeroforce and HPTuners and I can not get a case learn to go. The Aeroforce will not complete, it keeps going to the screen that says turn off and restart in 30 seconds and then nothing happens.
    In HPT I push the crank relearn button and it just lights up green and doesn't run me through the procedure.
  4. #44 Re: High knock-runs like crap.
    Jan 2017
    xx
    I'm in Pittsburgh and have DHP. I've never had any issues getting a case learn to complete. Could meet you half way and give it a shot if the car runs well enough for it.
  5. #45 Re: High knock-runs like crap.
    Mar 2017
    Internet
    Is the car above 180f? I believe that's a requirement, then when you hit the button you put the pedal down and it should do the trick
  6. #46 Re: High knock-runs like crap.
    Jan 2017
    xx
    Also, did you ever change the fuel filter after running a couple of tanks of E85? My filter was VERY clogged after just 1 tank.
  7. #47 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I appreciate that a ton digitaloutsider. I think it is fixed now.
    It just started running normal so I think one of the 20 case learns I tried finally took. I made sure the car was at full operating temp when I tried the case learn. HPT is looking to make the procedure more user friendly in a later version.
    I did change the filter after 2 tanks of the e85.
    Thanks everyone, hopefully the car is back to normal.
  8. #48 Re: High knock-runs like crap.
    Jan 2017
    xx
    That's great news!
  1. Help! new to site and grand prix's car runs like crap!
    By RuderGTP in forum General Tech Discussion
    Last Post: 04-26-2013, 09:39 AM
  2. 99 GT temp gauge runs high
    By Harley79 in forum General Tech Discussion
    Last Post: 02-08-2013, 04:44 PM
  3. Hi my car runs like crap!
    By Nick03gpgt in forum Introductions/Noob Questions
    Last Post: 12-21-2012, 03:58 PM
  4. New lateral rod; Car runs crap
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2010, 02:26 PM
  5. Engine runs like crap!
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2009, 02:26 AM
