all i can run is 13º wot from 4800 up iirc. other wise its KR city. and i hit 9.5 psi at 6000 rpm. will go higher with the 3.0 or 2.8, like 2 psi per pulley. but with each drop i need to cut more timing. and you start to not pull as hard with the timing cut to 9º, but the blower sounds cool lol
Interesting the difference between mine and yours. With my 18º and 10 psi i see no kr. I know that is my limit though because if i go to 19º i see kr, its low but its still there. Yeah i bet that would whine!
Are you talking about the coolant holes that flow to the TB, if so then yes those have been plugged. I didnt see any signs of coolant leaking around the lim gaskets either.
