Thread: Valve cover part number
Results 1 to 5 of 5
  1. #1 Valve cover part number
    Nov 2015
    WI
    I found out today that SC vs NA 3800 valve covers are not the same. So i have a new GM NA 3800 Rear (right) cover, and need to order the SC one. Can anyone confirm the GM part number so i dont screw up again! I believe it is 12590364.
    Thanks
  2. #2 Re: Valve cover part number
    my recall sheet from the dealer says the front was 12590363 so seems right.
  3. #3 Re: Valve cover part number
    Nov 2015
    WI
    Thanks Scotty.
  4. #4 Re: Valve cover part number
    Nov 2015
    WI
    Wanted to update this.
    Part number 12590364 is the correct one for the firewall side of a supercharged engine.
  5. #5 Re: Valve cover part number
    I don't want your update, Novak.
  1. Part number
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2014, 10:24 PM
  2. MAF part number for 02 gtp
    By jonygtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2012, 04:44 PM
  3. EVAP canister purge valve vacuum line part number
    By Freimuth in forum General Tech Discussion
    Last Post: 04-18-2012, 11:00 AM
  4. Looking for Throttle Valve (TV, kickdown) cable Part number:10142050
    By 90blackgrandprix in forum Shops and Community Heroes
    Last Post: 02-15-2012, 12:21 PM
  5. Need a Part Number....
    By webracin in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2008, 01:54 PM
