Thread: overkill tune
Results 1 to 9 of 9
  1. #1 Re: overkill tune
    Eh, see how it runs with the stock tune. You'd be suprised how well they will run if nearly no knock is present.
    They already run rich enough and run plenty of timing to keep the motor happy. If you needed anything it's likely code related or you want some transmission parameters changed.
  2. #2 Re: overkill tune
    Nov 2015
    WI
    I bought the car with what i thought was a stock pulley. It actually is a 3.4" So the torque app data i collected was with a 3.4" and not the 3.8" i thought. Mainly i was monitoring knock retard and at WOT the car was between 1 and 3 never saw anything higher.
    I was told that even a stock GTP will see those numbers (i told everyone i was running a stock pulley).
  1. after engineswap and overkill tune
    By kyleinkman in forum General Grand Prix Discussion
    Last Post: 12-29-2011, 11:18 PM
  2. can i use someone elses overkill tune..?
    By blknbstd in forum PCM Tuning
    Last Post: 09-07-2011, 11:08 PM
  3. Overkill re-tune or dont? worth it?
    By AmericanSoldier in forum PCM Tuning
    Last Post: 10-07-2010, 11:24 AM
  4. Modify Overkill tune?
    By bevernden in forum PCM Tuning
    Last Post: 08-20-2010, 05:45 PM
