Hello everyone i have a problem. i have a 2007 Grand Prix Gt i have a external coolant leak and its preety bad . ive changed the water pump, coolant elbows, radiator and thermostat.i still get a puddle of coolant on the ground
Check the o rings on the heater hose connections.
the puddle is running down the drivers side of the car forming 2 streaks between the driver side tire it also get small going to the passenger side. making you think its coming from the pulley side of the engine. but everrything has been replaced annd the same problem
yeah according to the radiator shop theyput a preesure test on it but could find the leak because it wouldnt leak bad. they should have put it on the rack to look under the car
here is a pic
you made it to small to get it to up load to the site, no idea what im looking at there. host it else where on the net.
http://www.grandprixforums.net/threa...es-for-dummies
here is a pic of the leak at another time
Check under the throttle body, there's a coolant passage in the throttle body.
hmmmmmm ill look ive had the throttlebody off about a month ago and i saw no coolanf then
O rings are in the alternator bracket.
are you talking about the coolant elbow o rings?
No. The heater hose connections to the alternator bracket are a loose fitting connection with o rings.
ok ill check no those two connections is dry as a powder house
Mine was just leaking out of the blue. So that's why I mentioned. Pics or video would help
