if you got one like this, you should make this bar to mount it with. bit hard to see but the ends are capped, drilled and tapped for a bolt. one end has the bolt in it. fits between th erad support. drill two holes to bolt through, then driill two holes at the bottom to mount the bottom tight.
folder full of install pics. you also need to cut the hood latch, i welded the top 1/2 to the bar thats holding the fmhe. what that L bracket was for originally.
http://s1097.photobucket.com/user/sc...?sort=3&page=1
