Is anyone using it? I know I read a post about an 06 gp using one but the can't let the tank go below 1/4 tank. I had the zzp350 pump and it was nice for the 9 months it lasted, it's being replaced under warranty. I had now problems with it while it worked.
I have a Venturi racetronix pump in right now but my canister is non Venturi on my Impala so it's not running right. When I get close to 1/4 tank, car struggles for fuel during hard braking and hard turns when low, ZZP pump didn't do this it was non Venturi.
What has to be done as far as "modifying" the canister for the aem to work? Or is it as simple as a regular fuel pump install? Impalas didn't come with Venturi pumps as far as I can find, the delco and Delphi replacement canisters are Venturi but I don't want to spend another $70-130 on a new canister. If someone has a way to fix my problem with the Venturi racetronix then I'll fix that but otherwise I have to find a non Venturi replacement.
