Thread: AEM Fuel Pump
Results 1 to 8 of 8
  1. #1 AEM Fuel Pump
    Quincy, Mass
    Is anyone using it? I know I read a post about an 06 gp using one but the can't let the tank go below 1/4 tank. I had the zzp350 pump and it was nice for the 9 months it lasted, it's being replaced under warranty. I had now problems with it while it worked.
    I have a Venturi racetronix pump in right now but my canister is non Venturi on my Impala so it's not running right. When I get close to 1/4 tank, car struggles for fuel during hard braking and hard turns when low, ZZP pump didn't do this it was non Venturi.
    What has to be done as far as "modifying" the canister for the aem to work? Or is it as simple as a regular fuel pump install? Impalas didn't come with Venturi pumps as far as I can find, the delco and Delphi replacement canisters are Venturi but I don't want to spend another $70-130 on a new canister. If someone has a way to fix my problem with the Venturi racetronix then I'll fix that but otherwise I have to find a non Venturi replacement.
    No more GP 04 Impala SS Indy:
  2. #2 Re: AEM Fuel Pump
    Omaha, NE
    Also interested in finding out what to do for a fuel pump upgrade 04+.
    If it helps, it looks like the part number ZZP uses for the AEM E85 pump is 50-1200.
  3. #3 Re: AEM Fuel Pump
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I have an AEM 50-1200 pump I am working on right now. If you install the pump with the pickup screen in the canister then below a quarter tank the pickup will be sucking air. If you install the pickup through the bottom of the canister then you get fuel slosh on hard turns. My idea is to replicate the factory pickup and install both screens so it can draw in and out of the canister. I will probably sell it once I am done as it is an extra one. This is the only solution I can think of. I tried running the pump both ways and neither produced satisfactory results hence the modification.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  4. #4 Re: AEM Fuel Pump
    Omaha, NE
    I guess this is always an option too...
    Quote Originally Posted by Tengis View Post
    As for 04+ I still really think adding a return line and doing a FPR is the best option for them =p. Get a line from 97-03 from the junkyard for like 20 bucks + the fuel rail for maybe another 20.
  5. #5 Re: AEM Fuel Pump
    Quincy, Mass
    I had the zzp350 pump in there with both screens and I had no problems, the racetronix isn't as talks the ZZP so it sits lower. But with or without the screen on the pump it did the same thing.
  6. #6 Re: AEM Fuel Pump
    Quincy, Mass
    What are the screens connected to in your pic? There's only one hole on the bottom of the pump.
  7. #7 Re: AEM Fuel Pump
    Jul 2014
    Toledo, OH
    The bottom screen connects to the AEM factory inlet. The interior canister screen goes into a hole I drilled next to the original pickup. The bottom of the pump between the green plastic and metal body inside is open all the way around where the pump draws in. The pump can draw from either inlet through this open chamber.
  8. #8 Re: AEM Fuel Pump
    Quincy, Mass
    Oh ok. My regular AEM pump (non e85 one) has a Venturi type hole that the instructions say to leave open so I'm go with that for now, see how that goes.
  1. 04/05 fuel pump install- Fuel pump access in trunk
    By chrsmi1 in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2015, 09:26 PM
  2. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  3. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  4. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
