Thread: Possibly bad iat sensor?
Results 1 to 19 of 19
  1. #1 Possibly bad iat sensor?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys i was looking for some help and knowledge on a potential problem with my intake temp sensor. I have a intense fwi setup on my car and the outside temp was 87 on my drive to work but my iat was anywhere between 145-151 and it barely fluctuated at all. Didnt matter if i was sitting at a stop light or doing 75 on the highway. This seems extremely odd to me that im getting such high temps. What do you guys think? Thanks
    Sent from my LG-H811 using Tapatalk
  2. #2 Re: Possibly bad iat sensor?
    Nov 2011
    NY
    Was the sensor actually in the intake plenum? It could have fallen out and been getting underhood temps...
  3. #3 Re: Possibly bad iat sensor?
    Oct 2015
    Yes it was inside the intake tubing
  4. #4 Re: Possibly bad iat sensor?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Bad sensor? Is your car still overheating? Or did you fix that?
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  5. #5 Re: Possibly bad iat sensor?
    Oct 2015
    I fixed the over heating thing
    Air had just got into the system so once i properly bled the air out all was well.
  6. #6 Re: Possibly bad iat sensor?
    Oct 2015
    Im talking about the intake temp sensor though not the coolant temp sensor
  7. #7 Re: Possibly bad iat sensor?
    Jul 2015
    Jamestown, NY
    Yeah I know what your talking about I was wondering if you still had other issues that could relate to this. All the sensor work off one another.
  8. #8 Re: Possibly bad iat sensor?
    Oct 2015
    Ya idk ill see what the temp is at right when i start it up tonight and if it says 100 and its 70 out and the engines cold ill replace it. I think its only 20$ anyway
  9. #9 Re: Possibly bad iat sensor?
    Oct 2015
    This is probably a dumb question but the ambient air temp sensor doesnt effect anything does it?
  10. #10 Re: Possibly bad iat sensor?
    sure does. why is it gone? lol
  11. #11 Re: Possibly bad iat sensor?
    Oct 2015
    Ya my ambient temp has been messed up since i bought the car itll jump from 50 to 122 randomly doesnt matter what the temp is outside. I just figured it was only there as a bell and whistle. What does it effect?
  12. #12 Re: Possibly bad iat sensor?
    it tells the pcm what your air temps are at the intake so the maf can adjust for it.
    try cleaning it, or pop a new one in, they are like 10 bucks. or the wires are bad to it. mine was all torn up, i had to replace the pig tail.
  13. #13 Re: Possibly bad iat sensor?
    Oct 2015
    No isnt that the intake air temp sensor. I was asking if the ambient sensor did anything. The one on the bumper?
  14. #14 Re: Possibly bad iat sensor?
    oh i see, what you get for jumping in with out a reading stuff lol
    not to the engine, but it can make your heat or ac from not work as it should.
  15. #15 Re: Possibly bad iat sensor?
    Oct 2015
    Ok thats what i figured. Thanks Scotty. But anyway shouldnt my iat be lower cruising on a freeway
  16. #16 Re: Possibly bad iat sensor?
    mine dont change much if at all, its picking up the ambient air temp.
  17. #17 Re: Possibly bad iat sensor?
    Oct 2015
    Ya but on my drive to work my temps stayed in between 145-151 the whole time wether i was stopped or cruising and the outside temp was 87.
  18. #18 Re: Possibly bad iat sensor?
    Oct 2015
    Ok so my car has been parked and not running for 7 hours its 77 degrees and my iat is reading 95 before i even start the car and my coolant temp is jumping inbetween 109-111?? Wth
  19. #19 Re: Possibly bad iat sensor?
    Jan 2014
    United States
    I have an 04 GTP and my IAT reads that high when I'm moving slow with a Hot Air intake setup. With a FWI I usually see around 10-15 degrees above ambient, sometimes it'll spike in traffic. Either way, you could have a dirty sensor. Try cleaning it with electronics spray or something maybe?
    Sent from my SM-G935T using Tapatalk
  1. Do I possibly have a bad crank position sensor?
    By tom5170 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2016, 04:12 PM
  2. 99 GTP MAF Sensor Issues (possibly)
    By JayHerlth in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2015, 10:48 AM
  3. Possibly looking for a new car
    By Bakerdd in forum Off Topic Discussion
    Last Post: 06-19-2011, 07:35 PM
  4. Could I maybe possibly almost???
    By jerZcavy4120 in forum General Tech Discussion
    Last Post: 04-28-2011, 10:22 PM
