Thread: boost gauges not working? and no boost at full throttle
Results 1 to 8 of 8
  1. #1 boost gauges not working? and no boost at full throttle
    Mar 2016
    Colorado
    Hey guys, I am trying to figure out why I have no boost and no vacuum in my car. even at full throttle there is nothing. and at park, in my 1997 gtp my in dash boost gauge will slowly go up. but im not on the gas, nor am i moving. please help! also! i am also running a 3.6 pulley, ( yes with supporting mods) i just pullyd up from a 3.4. it couldnt have been from me going up could it have?
  2. #2 Re: boost gauges not working? and no boost at full throttle
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    What supporting mods? And it could be just a simple MAP sensor.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: boost gauges not working? and no boost at full throttle
    Mar 2016
    Colorado
    headers, exhaust, tune, intake. If it is just the map sensor ill be happy... easy fix, right?
  4. #4 Re: boost gauges not working? and no boost at full throttle
    Kemmerer, Wyoming
    sounds like a vacuum leak, what are your fuel trims at when the car is idling?
  5. #5 Re: boost gauges not working? and no boost at full throttle
    Mar 2016
    Colorado
    well, i have a pre-cat exhaust leak. but that is just making my car surge at idle. I dont know what the fuel trims are, but you can smell the fuel running rich ( assuming that since my leak is between 2 o2 sensors its trying to compensate for something that isnt there. I've checked my lines i didnt see anything...
  6. #6 Re: boost gauges not working? and no boost at full throttle
    GXP Level Member
    Mar 2015
    Tomball
    You have a busted vacuum line. Follow them around and you will find it. The MAP gives you the signal for your boost gauge.
    Jeff
  7. #7 Re: boost gauges not working? and no boost at full throttle
    Buffalo
    I responded in chat
  8. #8 Re: boost gauges not working? and no boost at full throttle
    Mar 2016
    Colorado
    thanks guys
    ill see what I can do.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. 3.4 pulley and only 5 psi boost at full throttle?
    By bfox507 in forum General Grand Prix Discussion
    Last Post: 10-15-2014, 09:07 PM
  3. lag under full boost
    By notchy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2012, 09:26 AM
  4. not getting full boost
    By 02grandprixgtp in forum General Grand Prix Discussion
    Last Post: 09-22-2012, 10:43 PM
  5. not getting full boost?
    By Standby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 05:43 PM
