Fivefingerdeathpunch
The only way to for sure know is to degrease the whole bottom side where you think the leak is. Then onces it's clean you can stick your head under there and watch for the oil leaks. Remove the passenger side tire to help you look for the leak.
The most common on the passneger side are the oil pressure switch, oil filter housing gasket, timing cover gasket and front crank seal. Don't rule out the rear valve cover leaking oil out of the corner on the passenger side too, it could run down the engine block.
