Thread: Oil leak ??
Results 1 to 2 of 2
  1. #1 Oil leak ??
    Mar 2014
    New Orleans
    I've traced my leak thus far just need help I replaced the oil pressure switch then drove around "lightly" and made it back home I've noticed some smoke behind me but I figured that was the oil burning off that leaked but I checked under after leaving the car running and saw oil drop from above the oil filter housing thinking it's the front seal but that's not above the housing ??
  2. #2 Re: Oil leak ??
    You already have a thread on this issue.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
