Thread: Vacuum lines to/from Evap switch on 1997 GTP
Results 1 to 20 of 24
  1. #1 Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    I was getting a P0304 Code (Misfire #4) so I removed the sparkplug wire from #4 to check it and the plug. In the process, DUMB*** me knocked one of the vacuum lines off the evap switch. I have searched and can't find it and none of the vac line diagrams that I have been able to pull up show 3 line on the evap switch (only 2). Can anybody give me a diagram with 3 vac lines on the evap switch or tell me where the ines go from the switch? Thanks
  2. #2 Re: Vacuum lines to/from Evap switch on 1997 GTP
    if you knocked one line off put it back where it came from?
  3. #3 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    I wish it was that easy! As I said in the post, I knocked it off and now I can't find it. If I could just plug it back in I wouldn't be asking for a diagram.
  4. #4 Re: Vacuum lines to/from Evap switch on 1997 GTP
    oh, it dropped down on top of your exhaust manifold then. educated guess, mine wound up there once lol
  5. #5 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    I've checked that area many times already but I'll go check again. Be right back
  6. #6 Re: Vacuum lines to/from Evap switch on 1997 GTP
    what side you looking for? the engine side or the other side that leads off under the master cylinder?
  7. #7 Re: Vacuum lines to/from Evap switch on 1997 GTP
    mine had a white pinch clip on the end, you see it to the left of the red tranny dip stick. mt evap is deleted so its just hanging out back there.
  8. #8 Re: Vacuum lines to/from Evap switch on 1997 GTP
    this is the engine side, starts at the tb loops over the top to a hard line tot he evap.
  9. #9 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    I checked that area again and still no luck. The lines that are still connected go to the evap canister purge valve and to the evap canister. Any idea where the third one is supposed to go?
  10. #10 Re: Vacuum lines to/from Evap switch on 1997 GTP
    this is a 97
  11. #11 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    I have that diagram but it only shows 2 lines off the evap switch and mine has 3
  12. #12 Re: Vacuum lines to/from Evap switch on 1997 GTP
    post some pics of your set up.
  13. #13 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    This is my evap switch. As you can see there are2 hoses attached yo it and one open fitting. That's the one I can't find.
    Vacuum lines to/from Evap switch on 1997 GTP Attached Images
  14. #14 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    Don't know why but the photo came across upside down. The nipple is actually on the bottom of the swich pointing down towards the valve cover
  15. #15 Re: Vacuum lines to/from Evap switch on 1997 GTP
    im thinking its not a nipple at all. start the car, see if theres any vacuum pulling or pushing from it.
  16. #16 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    I'll do that but I know I knocked a hose off it.
  17. #17 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    As soon as I fire it up, it pops a P0171 code now. Having read more than one post about that code I know I've got a vacuum leak that I didn't have before I knocked the hose off.
  18. #18 Re: Vacuum lines to/from Evap switch on 1997 GTP
    pull out more with the camera so we can see the evap purge solenoid too. those two get linked together.
  19. #19 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    it has a hose that goes to the evap purge solenoid and it's connected
  20. #20 Re: Vacuum lines to/from Evap switch on 1997 GTP
    Aug 2016
    Vallejo,CA
    Where does the tee'd hose that runs under the battery and then back towards the firewall go? I know that the other side of the tee goes to a vacuum bulb in the driver side fender but I can't trace the other part of the tee. I'm wondering if that's the one that I knocked off and should be supplying vacuum to the evap switch. I'm just asking because I don't have a clue
  1. help with EVAP Vacuum switch
    By wowitsfast in forum General Tech Discussion
    Last Post: 12-05-2014, 09:24 PM
  2. Evap issue? Vacuum leak?
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2014, 11:22 AM
  3. Vacuum Lines
    By eshina17 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2014, 02:12 PM
  4. Vacuum lines
    By rtorres422 in forum Shops and Community Heroes
    Last Post: 05-24-2010, 10:18 PM
