Thread: Sooooo... Smoking after new rebuild...
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Sooooo... Smoking after new rebuild...
    Nov 2015
    Monroeville, Pa
    So I found the problem and prepare to have your mind blown... I pulled the piston out and found that the all 3 oil rings had coincidentally lined up with each other over a recess in the piston. This allowed the bottom oil ring to bend down into the recess and the wafer ring to over lap itself. And yes before you say it, yes all the rings were placed offset to each other during assembly and I have over 1000 miles on it since firing it up. Is there some kind of
    Sooooo... Smoking after new rebuild... Attached Images
    97 cavalier with L67 swap. F23 Getrag trans with stage 3+ SPEC clutch, KB pistons, L32 rods, LS6 valve springs, 3.4 pulley, ZZP downpipe 2.5, Full rotating assembly balance.
  2. #22 Re: Sooooo... Smoking after new rebuild...
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Nice find...
    Good stuff
  3. #23 Re: Sooooo... Smoking after new rebuild...
    GTP Level Member
    Pittsburgh
    interesting, that would never happen again even if you tried
    2003 SSEi,
  1. Smoking is bad
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 09-12-2011, 07:57 PM
  2. Smoking in your car
    By Dobbs122 in forum Off Topic Discussion
    Last Post: 08-03-2011, 06:46 AM
  3. HMMMMM..... sooooo
    By kbrown in forum Off Topic Discussion
    Last Post: 05-18-2011, 10:10 PM
  4. Just got the cat. sooooo
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 05-09-2011, 08:45 PM
  5. I'll have what he's smoking
    By gpgt04 in forum Off Topic Discussion
    Last Post: 08-11-2010, 01:12 AM
