Thread: Weird stalling and low oil level issue? Nobody knows.
Results 1 to 10 of 10
  1. #1 Re: Weird stalling and low oil level issue? Nobody knows.
    you can double check, see if the # on the top of the maf is the same, if it is, your golden there.
    theres always bad grounds, dirty terminals and such. if you see any bare wire at the cable ends the cable could be bad too. main ground is on the tranny bell housing bolt. theres 2 other grounds there, make sure they are all ok. no bare wire to be found.
  2. #2 Re: Weird stalling and low oil level issue? Nobody knows.
    SE Level Member LNVFX's Avatar
    Nov 2015
    Ohio
    A bit dark out at the moment, but I'll check when I wake up tomorrow.
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. Stalling Issue
    By codyjoe in forum Introductions/Noob Questions
    Last Post: 05-12-2013, 07:17 AM
  3. 99 GTP Stalling, other weird stuff
    By BReddy in forum General Tech Discussion
    Last Post: 05-09-2012, 01:45 PM
  4. Stalling Hot Issue Need Help...
    By BPGPSE in forum General Tech Discussion
    Last Post: 06-13-2010, 09:26 PM
  5. MAF / stalling issue
    By the1euge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 11:16 AM
