Thread: Bad water pump?
Page 5 of 5 FirstFirst ... 345
Results 81 to 93 of 93
  1. #81 Re: Bad water pump?
    your a damn mechanic now.
  2. #82 Re: Bad water pump?
    GTP Level Member
    Oct 2014
    Getting there. Quite the learning experience. One last question and then I will kill this thread. How do you tell if a radiator cap is bad.
  3. #83 Re: Bad water pump?
    the over flow tank can be over flowing or coolant leaking up from under it. they do wear out, inside is a rubber seal, if its torn up you know the cap is bad.
    you'll want to bleed the t stat housing too, theres a bleeder screw a top it, open it up when the cars warmed up leave it open till a steam of coolant comes out.
    i like to leave the rad cap off let it idle till the fans come on, this way you know the t stat is open, bleed it, then top off the rad and cap it.
    drive it as needed, next morning check the level in the rad. if its low top it off.
    fill the over flow tank to the cold mark if its low or empty.
    the way the tank works is the engine gets how, the coolant has to go somewhere, so it pushes out the past the cap to the tank, when it cools it draws it back in the rad. so make sure that line to the tank is not busted up or leaking at its ends.
    rad tanks also crack can be hard to see sometimes, will only leak once the engine is warmed up most of the time, and you find it low on coolant when it was full the day before.
  4. #84 Re: Bad water pump?
    GTP Level Member
    Oct 2014
    Yes I did all that. I installed a new t stat and drilled a tiny hole in the flange. ( not sure that that helps anything or not). But yesterday when I had it up to temp and out running then back in the driveway I poped the hood and squeezed the upper radiator hose and could hear it sloshing in the overflow tank. No pressure built up. Which seemed weird to me. That had me thinking the cap could be bad. But it built pressure before with the hissing. So just a little puzzled.
  5. #85 Re: Bad water pump?
    they are cheap enough to just swap out. mine took a crap i got one with the red locking lever on it. seems to be holding up well the last 3 years now i guess.
  6. #86 Re: Bad water pump?
    GTP Level Member
    Oct 2014
    Yea that's what I was thinking.
  7. #87 Re: Bad water pump?
    Dec 2016
    oregon
    How to remove the supercharger pulley that's in the way of taking off the water pump in 1997 GP
    GTP?
  8. #88 Re: Bad water pump?
    the lower idler? its a t55 torx. normal threads. p/s pump also has to come off to get the other two long bolts out.
  9. #89 Re: Bad water pump?
    Dec 2016
    oregon
    How did you remove the supercharger belt pulley in order to remove the lower right hand bolt on water pump?
    Thanks
  10. #90 Re: Bad water pump?
    i just told ya. read fred. read.
  11. #91 Re: Bad water pump?
    Dec 2016
    oregon
    Thanks so much. I'll give it a try. Tried Allen wrench and that didn't work.
    Fred
  12. #92 Re: Bad water pump?
    might be a T50. its one of them.
  13. #93 Re: Bad water pump?
    GTP Level Member
    Oct 2014
    Bump for "revtron"
  1. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  2. water pump
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2012, 07:57 AM
  3. Water Pump
    By blaqdiamondz46 in forum General Tech Discussion
    Last Post: 11-11-2011, 05:25 PM
  4. Water Pump
    Last Post: 11-11-2011, 03:29 PM
  5. Water pump
    By robblk04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2011, 03:18 PM
