Thread: EVAP Leak
Results 1 to 15 of 15
  1. #1 EVAP Leak
    Mar 2016
    Omaha
    After installing my headers, my car threw a code for an Evap system leak. I've replaced the evap solenoid and a busted vacuum line off of said solenoid. I did find a b-nut connection which will be pictured that was disconnected but I see no where to connect it. Just wondering if it is my headers or if this connection has something to do with it.
    Below is the b-nut I'm talking about, similar ones are connected to the box just below it, I figure is something to with the fuel system.
  2. #2 Re: EVAP Leak
    Headers and evap don't go together, installing headers will have no effect on the EVAP system.
    You link to the picture didn't work.
  3. #3 Re: EVAP Leak
    you likely cracked the fat vac line off the TB.
    whats a B nut? and dead link.
  4. #4 Re: EVAP Leak
    Mar 2016
    Omaha
    Idk what's wrong with the link, I tried resetting it to get it to work. Is a male threaded but, but I can't find a female side to thread it into. We call it a b-nut in the military maintenance world, I don't know what else is called.
  5. #5 Re: EVAP Leak
    That metal line with the nut above the ABS module is not a EVAP line, looks like an old brake line.
  6. #6 Re: EVAP Leak
    Mar 2016
    Omaha
    So what I'm looking at is not the problem? I will continue to chase this problem then. Thanks guys.
  7. #7 Re: EVAP Leak
    thats a line nut in the civilian world. we use a line wrench on it. not evap related all like stated already.
    im guessing you have a 97-03 if you do theres this fat vac line from the tb to the evap solenoid on the back of the engine, it cracks.
    the repair is a fat line that fits the port, then a smaller pushed inside the fat one to the hard plastic line.
  8. #8 Re: EVAP Leak
    Quote Originally Posted by WootyGTP View Post
    blow in the line, if air blows clean through its a old brake line that rusted out and never got removed.
  9. #9 Re: EVAP Leak
    Mar 2016
    Omaha
    Line nut, I'll keep that in mind, I'll go take a look at said vacuum line, the smaller line did come out super easy, so maybe it's cracked some where that isn't visible easily.
  10. #10 Re: EVAP Leak
    mine cracked in the curve of the line. theres a damn good chance you leaned on it and it cracked. they are very brittle after 15 years of heat.
  11. #11 Re: EVAP Leak
    Mar 2016
    Omaha
    It seems that this fix has already been done.
  12. #12 Re: EVAP Leak
    you got the evap plugged back in? or make sure its plugged in still. clips break off and crap happens when your doing work.
    whats the code your getting? leak or voltage?
  13. #13 Re: EVAP Leak
    Mar 2016
    Omaha
    I'm getting a p0442, just checked the pligs, everything is connected, I figure the next step would be a smoke test.
  14. #14 Re: EVAP Leak
    could be the gas cap. its on right? id clear the code, take the gas cap off and put it back on, then drive the car and see if it comes back.
    i live in NJ, so i dont have to pump my own gas, dummy left my cap loose and the light came on with in blocks of the fill up, checked the cap, made that tight and the light went off in a few blocks on its own.
  15. #15 Re: EVAP Leak
    Mar 2016
    Omaha
    That was one of the first things I did, no fix. I'm thinking I hit something while installing my headers, I'll do some more looking around tomorrow during the day.
  1. Evap Leak
    By gordster1122 in forum General Tech Discussion
    Last Post: 01-16-2015, 10:10 PM
  2. Evap issue? Vacuum leak?
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2014, 11:22 AM
  3. Evap leak and surging in 4th
    By vtechkiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2012, 01:53 PM
  4. Evap system leak in '06 GXP
    By GPGXP06 in forum 5.3L V8 (LS4)
    Last Post: 06-13-2012, 10:30 AM
  5. evap leak need help
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 08:58 PM
