Thread: Smokes at idle!!!!
Results 1 to 20 of 50
  1. #1 Re: Smokes at idle!!!!
    GXP Level Member
    Mar 2015
    Tomball
    A lot of the L67's crack between the valves and don't smoke. Pretty sure Scotty has some pics. I would check the valve guides you may have a super sloppy one that needs to have a new bronze guide pressed in or at least knurled. If it's sloppy as a few I have seen I wouldn't be suprised by the smoking at idle at all.
  2. #2 Re: Smokes at idle!!!!
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Quote Originally Posted by J57ltr View Post
    Its just weird that the two cylinders next to each other are doing this. They are Hinson ported heads and the guides were milled down I'm pretty sure to accept a larger lift in the future. Unsure how he does this but if they are leaking it sounds like the head must come off no matter what , then be sent out to a machine shop to have everything checked.
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  3. #3 Re: Smokes at idle!!!!
    GXP Level Member
    Mar 2015
    Tomball
    http://www.grandprixforums.net/threa...ghlight=hinson
    Post #148 shows what I think the issue could be.
    Jeff
  4. #4 Re: Smokes at idle!!!!
    Jul 2008
    Hooksett,NH
    Jeff
    Reading the first page I'm not very happy! lol. But reading post 148 a new crank does not make sense to me. My timing gear is chamfered.
    02 Regal GS
  1. When coil pack module is connected the wire harness gets hot and smokes *UPDATE*!!
    By SuperchargedIntrigue in forum General Tech Discussion
    Last Post: 05-11-2015, 09:48 PM
  2. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  3. burning coolant:( smokes when i shut it down
    By gtcoup in forum General Tech Discussion
    Last Post: 01-31-2011, 12:08 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
