Thread: power steering high pressue hose
Results 1 to 3 of 3
alenw62 power steering high pressue... 08-06-2016, 08:28 PM
Turbocharged400sbc Re: power steering high... 08-06-2016, 08:35 PM
Turbocharged400sbc Re: power steering high... 08-06-2016, 08:58 PM
  1. #1 power steering high pressue hose
    Apr 2016
    Dalton, GA
    Installing high pressure power steering line got the end on the rack already The problem is getting the pump fitting lined up right which way does all the excess hose go to get the fitting to line up right.
  2. #2 Re: power steering high pressue hose
    hangover park IL
    the hose is twisted into a corkscrew/spiral, goes in a loop upward then down to pump end of the hose (L shaped hardline)
    ~James~ Psychotic Gearhead
  3. #3 Re: power steering high pressue hose
    hangover park IL
    this is a different engine but you can see how the hose is coiled, both are the same only the metal end going to the pump is shaped differently, but the rubber hose is coiled the same
  1. high pressure power steering hose 2006 3.8
    By tajacks2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2015, 05:58 PM
  2. power steering hose leaking, is my mechanic ripping me off?
    By GPfoSHEEZY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-24-2014, 03:53 PM
  3. Power steering pressure hose
    By chevyy1212 in forum General Tech Discussion
    Last Post: 09-20-2012, 10:17 PM
  4. Anyone got a write up one Power Steering pressure hose
    Last Post: 02-20-2012, 08:18 PM
  5. How to replace Power Steering Hose
    By webxfx in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-09-2010, 07:56 AM
