Thread: Randomly goes +16 ltft 10.1AFR stalls P1133
Results 1 to 19 of 19
  1. #1 Re: Randomly goes +16 ltft 10.1AFR stalls P1133
    should not need the rear o2 at all if the cat test is truly turned off.
    you got the stock pcm still? if so pop it in and see if it does the same thing. you'll get a rear o2 code asap cause its not plugged in, but the fuel trims will might turn normal.
    if you have the rear o2 still, put it back in for the test.
  2. #2 Re: Randomly goes +16 ltft 10.1AFR stalls P1133
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    I put the old PCM in does the same thing right off the back even tried learning it with no luck. It runs fine if I unplug the o2 and run it off the maf if that helps at all.
  1. help! 2000 gtp stalls randomly then starts up 5 minutes later!
    By chicagosleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2013, 01:54 PM
  2. grand prix gt randomly stalls
    By Arzona Miller in forum General Grand Prix Discussion
    Last Post: 06-29-2012, 05:33 PM
  3. 97 Grand Prix GT very randomly stalls at idle
    By Deebo in forum General Tech Discussion
    Last Post: 02-20-2011, 01:09 AM
  4. p1133 code
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2011, 10:57 PM
  5. 1995 GP Stalls Randomly;Otherwise fine
    By hacket in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-16-2010, 11:55 AM
