Thread: Had the Fuel Injectors Cleaned
Results 1 to 19 of 19
  1. #1 Had the Fuel Injectors Cleaned
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Was using Mr Injector out in Idaho, found a place here on LI (actually 2, but one really close by) that use the same ASNU ultrasonic cleaning technology. These are from a 2002 GTP, stock. Look at the flow before and after, they were only flowing at about 2/3 of what they are supposed to.
  2. #2 Re: Had the Fuel Injectors Cleaned
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    can you notice a difference in how the car runs ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  3. #3 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    Not yet....picking them up tomorrow, just got the report via email this evening. Fuel rail was out since SC bearings went bad. New reman SC from PSE in OK, ported and going in too. Will post back when it's together
    Sent from my SM-G930V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  4. #4 Re: Had the Fuel Injectors Cleaned
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    How much did he charge?
    GPONA #1 Cyber Bully
  5. #5 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    Its $22 per injector
  6. #6 Re: Had the Fuel Injectors Cleaned
    GXP Level Member
    Mar 2015
    Tomball
    Holy crap $22 per injector? Need to get my injector test stand back in operation.
    Jeff
  7. #7 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    That also includes new filters, pintles and O-rings
  8. #8 Re: Had the Fuel Injectors Cleaned
    SE Level Member b4black's Avatar
    Oswego, IL
    I use an ASNU where I work. I'm surprised to see all six injectors dirty nearly the same like that. I also would think that if there were only following ~60%, they would have tripped the Check Engine light. That's a lot of fuel to make up with LTFT adjustments.
    I'm also surprised to see they all cleaned up to within 2cc of each other.
  9. #9 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    I agree. I had the injectors ASNU cleaned on the 98 and the 01 and they cleaned up similarly, I will have to go back and see what the "before" numbers were.
    Agree with you, I actually checked to be sure he had the right part# and specs, and it's correct. Does seem fishy for them to be so clogged. I'll see if I can get more info when I go pick them up today.
  10. #10 Re: Had the Fuel Injectors Cleaned
    GXP Level Member
    Mar 2015
    Tomball
    I use a different machine, it's a Star brand and is pretty old, but does everything that you need for cleaning fuel injectors. I can backflush, ultrasonically clean (separate unit) check balance and do leakdown tests. You would be suprised how much injectors can clog up. I never really saw it as bad on disc type injectors, usually the screens were dirty and a backflush would make a hell of a difference, though not as much as you posted. Most of the issues I had were with pintle style injectors. Fuel injector cleaners are bunk and don't do anything. I just need to check the machine out again and get the platter fixed so it'll do balance testing again.
  11. #11 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    Cool! So I wound up at $120 cash, so $20 each, not bad
  12. #12 Re: Had the Fuel Injectors Cleaned
    SE Level Member jimzssei's Avatar
    Sep 2014
    Curious to know how much different the car runs, including any mpg difference. 👍
  13. #13 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    Just noticed today that the DIC os showing 19, never got above 18before.
  14. #14 Re: Had the Fuel Injectors Cleaned
    GTP Level Member
    Oct 2014
    ^^^^ no grandma driving there.
    Sent from my iPad using Tapatalk
  15. #15 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    The car runs a whole lot better than before...but that's also a reman and ported SC, a squeaky clean LIM with new gasket, new vacuum lines and the cleaned injectors, so hard to say how much is due to injectors alone. Wasn't like i was cleaning them to fix a problem, just because they were out anyway..
    What do you guys get for mileage on a GTP?
  16. #16 Re: Had the Fuel Injectors Cleaned
    I was a 90% city driver when I owned my car, it got 14-16 city in the summer and maybe saw 18ish if I drove normal. Freeway was always 30-32 going up to the cabin doing 65-70mph.
  17. #17 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
  18. #18 Re: Had the Fuel Injectors Cleaned
    GTP Level Member
    Oct 2014
    My daughters 2007 gets about 20-21 mainly city driving. Don't think she is into the boost much. My other daughters 2003. I drove for about 3 weeks for work. Highway miles. Not into boost much. And got about 24 ish. I had the DIC up to 25 for a while with 1200 miles on the reset but never hand calculated that high.
  19. #19 Re: Had the Fuel Injectors Cleaned
    Dec 2008
    ****'s Creek
    Yeah, I LIKE the boost...
  1. Had injectors cleaned and balanced
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 09-23-2014, 08:07 AM
  2. Replies: 9
    Last Post: 08-20-2014, 04:16 PM
