Thread: Is this enough for a 3.4" pulley
Results 1 to 20 of 22
  1. #1 Is this enough for a 3.4" pulley
    Mar 2016
    Rochester, NY
    I have a Series 3 motor with Series 2 internals, Gen V, 180* stat, autolite 104 plugs, SP headers, will be buying an exhauast soon, and a ZZP PCM and having a 3800 knowledgeable friend tune it. Still not sure after a lot of research. If not, what size can I run, or what else would be needed to safely use a 3.4"
    Thanks
    *edit* car is an '4 Comp G and am also doing an EGR delete
  2. #2 Re: Is this enough for a 3.4" pulley
    3.6 might be safer with the gen 5.
  3. #3 Re: Is this enough for a 3.4" pulley
    Avoid a mail order zzp tune
    3.6 for those mods, but you'll need either cam/rockers/ic/e85 can get you to a 3.4 or lower knock free with good timing
    Edit: damn u scotty
    04 Comp G.
  4. #4 Re: Is this enough for a 3.4" pulley
    Mar 2016
    Rochester, NY
    I'm just buying the PCM itself and getting it tuned by someone else, and for your list, is all that needed or I can pick one to be able to run the 3.4"?
  5. #5 Re: Is this enough for a 3.4" pulley
    Yup pick one
    Rockers would be the easier/cheaper out of the list if e85 isn't available
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  6. #6 Re: Is this enough for a 3.4" pulley
    Mar 2016
    Rochester, NY
    Alright cool, thanks for the help
  7. #7 Re: Is this enough for a 3.4" pulley
    Also exhaust is not needed at that level unless your after tone of just wanna replace the thing, restrictive part is the stock bend downpipe which you'll be taking care of with headers
    04 Comp G.
  8. #8 Re: Is this enough for a 3.4" pulley
    currently on 3.4 gen5 tog headers with 60# injectors and e85 though.
    i suggest e85 because well e85allthe3800s!
    lol
  9. #9 Re: Is this enough for a 3.4" pulley
    Why not just tune the stock computer??
    You don't have to buy another PCM to tune these cars.
  10. #10 Re: Is this enough for a 3.4" pulley
    Buffalo
    Sweet. A slammed fiero rockin a 3800 in Rochester? Awesome. Love to see it sometime
  11. #11 Re: Is this enough for a 3.4" pulley
    Mar 2016
    Rochester, NY
    That's the goal... But right now its got a stock motor and is being restored. This is all for my GTP
  12. #12 Re: Is this enough for a 3.4" pulley
    Jan 2012
    Pennsylvania
    It will all come down to the tune. Kr being the biggest issue. On my 2000 gtp I had those mods and was able to run 13.5s all day long with only one other mod and that was alky injection.(imitation I/C). Now on my 04 comp the kr was much more of a problem. I had to go a different route and now I'm tuned for a 2.9" but that all came with a much higher price tag. I am equipped to run alky on on 04 but it really doesn't do any good because I don't have any knock.
  13. #13 Re: Is this enough for a 3.4" pulley
    Quote Originally Posted by gtpsgofast View Post
    you must be on e85. or running no timing at all to use a 2.9 pulley kr free.
  14. #14 Re: Is this enough for a 3.4" pulley
    SE Level Member d68barnes's Avatar
    Apr 2016
    I ran 3.4 with air box down pipe cat delete and 103 plugs with no problems in to different gtp I had
    Sent from my HTC Desire 626s using Tapatalk
  15. #15 Re: Is this enough for a 3.4" pulley
    Quote Originally Posted by d68barnes View Post
    Good luck with that combo on a GEN 5 supercharger lol, need a junkyard on speed dial for sure.
  16. #16 Re: Is this enough for a 3.4" pulley
    Apr 2016
    Does running gen v that much different my two cars ran that set up minus hen v for year one is still running
  17. #17 Re: Is this enough for a 3.4" pulley
    Gen v is a much more efficient blower. Gen v 3.6 = gen III 3.4
    That's the general rule of thumb, don't get pulley happy or you'll met chip soon enough
    And what works for one person doesn't mean it'll work for other people
    04 Comp G.
  18. #18 Re: Is this enough for a 3.4" pulley
    I know you said it works, but is everything still healthy.
    It may run but if you were to log the data from the computer and it shows alot of knock with that pulley and minimal mods, they in reality it's not running good and just hurting power. Using 3 range cooler plugs and only a downpipe/cat delete isn't a real good way of modding. (the air box isn't even a mod that adds power, so I excluded that)
  19. #19 Re: Is this enough for a 3.4" pulley
    Apr 2016
    I didn't realize that gen v made that much difference old cars was running gen 3
  20. #20 Re: Is this enough for a 3.4" pulley
    Just because it runs, doesn't mean it is running WELL.
    Remember that, too.
    I'd bet money on it a tuned car on a stock pulley that is KR free across the board will (with a comparable blower) would skull drag a knocking car on a similar blower with a smaller pulley.
    But the pullied car makes cooler noises.
  1. 3.5 pulley, TB Spacer, PLOG, other "go fast" goodies
    By GTPlzz in forum Wanted To Buy - Parts
    Last Post: 02-13-2014, 04:27 PM
