Thread: Help!! please
Results 1 to 4 of 4
  1. #1 Help!! please
    SE Level Member Fasano44's Avatar
    Apr 2011
    Manville nj
    I have a 1997 gtp, a lot of modifications including ported upper and lower intake, 3'4 pulley on s/c, TOG headers with 3" zzp exhaust. Autolite 103 plugs gaps accordingly, Northstar throttle body with adapter, msd coil packs but im having a problem with the idle going all over the place, at times itl stay steady around 800 but other times it gets stuck around 1500 and doesnt come down until i put it into gear, has anyone had this sort of problem? any information is appreciated thank you!
  2. #2 Re: Help!! please
    sounds like a vac leak. spray the vac lines with carb cleaner listen for the idle to jump.
    and 103 plugs are to cold, 104's gaped at 0.50 would be better.
  3. #3 Re: Help!! please
    GT Level Member mguzzo's Avatar
    Buffalo NY
    and gapping to 0.050" would be better still ;-)
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: Help!! please
    Kemmerer, Wyoming
    One time I installed a set of new 103's and forgot to gap them, they had the factory gap of .035. It didn't mess the idle up, but the car ran lean for the minute it took me to remember I hadn't gapped the plugs
