Thread: Engine torque noise
Results 1 to 9 of 9
  1. #1 Engine torque noise
    Dec 2014
    Fort Wayne, IN
    2001 GTP 192k - I have a knocking noise when I accelerate and the same noise as I let off the pedal. I thought for sure it was motor mounts but I have replaced both trans mount and lower mount and no change. The dog bones appear to be in good condition. I have also just replaced the transmission. Any ideas?
  2. #2 Re: Engine torque noise
    post a vid, could be anything from a cracked flex plate to a rod knock.
  3. #3 Re: Engine torque noise
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Does it make the noise when in idle? It could be a bad supercharger.
  4. #4 Re: Engine torque noise
    Dec 2014
    Fort Wayne, IN
    The noise isn't related to rpm, it's more like how a wooden floor would creak as you apply your weight and then creak again as you unweight it.
  5. #5 Re: Engine torque noise
    St. Louis
    Could be subframe bushings, or maybe control arm bushings.
  6. #6 Re: Engine torque noise
    Dec 2014
    Fort Wayne, IN
    I had a friend put the e brake on, his left foot on the brake and put in drive and pulse the throttle. I can observe the engine rock back under the torque load, then after it returns to idle the engine slowly rocks forward again I can hear the slow creaking sound. I have ruled out the motor mounts as they are both new.
  7. #7 Re: Engine torque noise
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    New upper or lower mounts?
    Edit: nevermind, i read the original post
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  8. #8 Re: Engine torque noise
    Dec 2014
    Fort Wayne, IN
    From the driver seat the sound is coming from the center of the engine compartment and not one side or the other.
  9. #9 Re: Engine torque noise
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    My first thought was a bad CV joint.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. Engine torque specs.
    By TheOtherNick in forum General Tech Discussion
    Last Post: 06-07-2016, 11:49 PM
  2. 2007 GP Base Engine Torque Mount Bracket Passenger Side
    By eetchickn in forum Wanted To Buy - Parts
    Last Post: 09-04-2013, 05:27 PM
  3. Creaking/Squeaking noise during acceleration or application of engine torque
    By densmith123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-06-2012, 12:43 AM
  4. Upper Engine Torque Strut Mount Bolt Question
    By janaya3 in forum General Grand Prix Discussion
    Last Post: 01-30-2012, 11:46 AM
  5. Max engine torque for upshift
    By Juanmiguel in forum PCM Tuning
    Last Post: 05-15-2011, 02:27 PM
