Thread: Head gaskets?
Results 1 to 12 of 12
  1. #1 Head gaskets?
    SE Level Member gofast's Avatar
    Mar 2016
    Has anyone ever seen a head gasket blow just between #2 & #4 cylinder causing low compression? Runs great when cold and misses on #2 & #4 when warmed up and at at least 3psi or more of boost. No oil in water or water in oil. Motor is smooth and strong for everything when it's not boosting. Thank you
    Sent from my SM-G900R4 using Tapatalk
  2. #2 Re: Head gaskets?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    It's pretty rare for the head gaskets to go on these. Have you checked the compression?
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: Head gaskets?
    Mar 2016
    The dealership did the compression test and said it was low on #2 & #4. The head gaskets were replaced less than a yr ago by the previous owner.
  4. #4 Re: Head gaskets?
    could be two bad plug wires, melted on the manifold.
  5. #5 Re: Head gaskets?
    Mar 2016
    I wish that's all it was. Lol.
  6. #6 Re: Head gaskets?
    ppl have cracked plugs installing them too. or used plats and got misfires as well.
  7. #7 Re: Head gaskets?
    Mar 2016
    But that wouldn't cause low compression on those 2 cylinders.
  8. #8 Re: Head gaskets?
    burnt valves if both are low on compression, and your not loosing coolant at all.
  9. #9 Re: Head gaskets?
    Mar 2016
    I thought that too but maybe being 2 cylinders next to each other might be a gasket issue?
  10. #10 Re: Head gaskets?
    Mar 2016
    If it were burnt valves wouldn't it still misfire when the motor is cold? It runs good even at WOT at full boost when the motor is cold. I knkw that's not the way to treat a cold motor bit I tried it today and it worked great when cold.
  11. #11 Re: Head gaskets?
    Dec 2012
    Where 4T65E's were born
    The fact alone that the head gasket was already done, increases the chances it may actually be blown now. I trust the factory more.
    Sold.
  12. #12 Re: Head gaskets?
    Mar 2016
    Found the problem, cracked head between #4 & #6 cylinders
  1. Head Gaskets LIM, and more.
    By 04lss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2015, 06:51 PM
  2. WTB: ARP Head Studs & Head Gaskets, FelPro or Multi Layer
    By JordanGT in forum Wanted To Buy - Parts
    Last Post: 03-05-2015, 12:51 AM
  3. Which head gaskets?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2012, 07:12 PM
  4. $$$$$$ 4 Head gaskets
    By Octane in forum Engine
    Last Post: 01-06-2011, 12:54 AM
  5. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
