Im Going to be installing a few go fast things on a car and had a question about the double roller setup. I have a brandy new Rollmaster purchased from ZZP 2 years ago still in the plastic that will be used I have heard some people say that the Crank Gear needs Machined to match the Stock Crank Gear Chamfer, and others including ZZPoop say that "we have never had an issue installing as-is" with out the chamfer. ZZP also goes on to say "they believe it was only early Rollmasters that had a fitment issue"
I have a OEM Crank gear that I could send to the machine shop to get the Rollmaster matched, but if I don't have to spend the money then why bother?
I already have the Machined Oil Pump Cover and double thick gasket for the timing set.
Looking for real world experiences on this one
