Thread: Xp cam help
Results 1 to 14 of 14
  1. #1 Xp cam help
    May 2015
    Lincoln, NE
    I'm in need of some help for my xp build on my 02 gtp. I got a little ahead of myself and didn't line up the timing marks and car is horribly off time. How would I time it?
  2. #2 Re: Xp cam help
    stop running it before you smash a valve into a piston for one.
    now take it apart again and set your timing chain up right. if your lucky the engine not dead already.
  3. #3 Re: Xp cam help
    The 3800 is a non interference motor, he's not going to damage it that way.
    But you are going to have to redo everything, the timing marks must be lined up correctly or this motor isn't going to run. Why would you throw it back together if you knew you didn't get it right?
  4. #4 Re: Xp cam help
    Buffalo
    It's easy to forget until it's too late. Which is why people should read read read before they do stuff
    Simple answer - start over again from the beginning
  5. #5 Re: Xp cam help
    May 2008
    Schuyler, NE
    Sorry, the 3800 is an interference motor.
    You probably bent some valves. Pull the front cover off and retime it. You are most likely going to be replacing valves though.
  6. #6 Re: Xp cam help
    May 2008
    Schuyler, NE
    I had an "oops" a few years ago.
  7. #7 Re: Xp cam help
    May 2015
    Lincoln, NE
    I started it once and heard it then shut if off I didn't want to keep running it.
  8. #8 Re: Xp cam help
    May 2008
    Schuyler, NE
    You're from Lincoln, huh?
    We are only a hour apart.
    You can hook up a compressor and check to see if the valves are sealing. If they don't seal while turning the motor over by hand, you are going to be pulling the heads.
  9. #9 Re: Xp cam help
    May 2015
    Lincoln, NE
    Ya I'm from lincoln but the car is in kearney as I do not have a garage. It was a dumb moment of mine. I'll be down again on the weekend to work on it again
  10. #10 Re: Xp cam help
    May 2008
    Schuyler, NE
    Are you going to take it to krp when done?
  11. #11 Re: Xp cam help
    May 2015
    Lincoln, NE
    Yes after I'm done, I will more than likely take that and my slow gxp also.
  12. #12 Re: Xp cam help
    May 2008
    Schuyler, NE
    Nice. I have a buddy in Lincoln with a turbo gp GT. He's trying to get it into the 10's this summer.
  13. #13 Re: Xp cam help
    May 2015
    Lincoln, NE
    Nice I wanna trade my gxp for a goat
  14. #14 Re: Xp cam help
    May 2015
    Lincoln, NE
    Found the problem. It was off timing and the key flew off for the cam. Thanks for the help guys
