Thread: Abnormal amount of KR
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
  1. #1 Abnormal amount of KR
    Mar 2016
    Colorado
    So I have just put on my 3.4" pulley, and I got a tune. The problem is that when my tuner was going at it, he could not possibly get the knock retard down. at full throttle I have almost 13-16* of it. When he showed me, the supercharger was whining and then the whine would suddenly become quieter as if there was a lack of fuel. He suggested to buy a new fuel filter, then also change the spark plug wires. I'm waiting on the wires but just wanted to see what you guys thought of this predicament
  2. #2 Re: Abnormal amount of KR
    Any other mods and what vehicle is this?
  3. #3 Re: Abnormal amount of KR
    not seeing a scan, who knows. thats a lot of kr.
    you got headers on it yet? if not you want them asap or take the pulley off.
    fuel pump could be bad, your guy should have tested the pressure at the rail.
    was this a dyno shop with a wideband? or a local with a tuner/ pal?
  4. #4 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    I've got a custom intake, obx headers, 3" exhaust down to the the y-split then 2.5" to the mufflers. it was a local friend that has been tuning the 3800 for 12 years too. Narrowband I believe. It is a 1997 GTP
  5. #5 Re: Abnormal amount of KR
    I'd be curious if it's going lean on you. A wideband is a must in my eyes, I don't trust narrow bands for anything but idle and cruise situations.
  6. #6 Re: Abnormal amount of KR
    if you can get some screen shots of the scan it may help. hard to say sitting all the way over here lol
  7. #7 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    He set it at runnning 17% rich to try and combat it
  8. #8 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    This was on saturday, so I dont think i can get a screen shot of it. Sorry
  9. #9 Re: Abnormal amount of KR
    whats your wot timing?
    17% is flooding it, and its not working either.
    whats he using to tune with? hp, dhp?
  10. #10 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    The timing is super frickin low.
    I believe he uses hp i just asked him now
  11. #11 Re: Abnormal amount of KR
    Quote Originally Posted by jeannelle101 View Post
    In tuning jargon that means nothing to me. Say it's set to run rich by a percentage is not correct really. There is a set AFR that you should be commanding while in performance enrichment, like say 11.0 or 11.5.
    If you have a target AFR and the wideband is saying otherwise, it needs to be corrected. Say it's on the lean side of 11.0, it might be running out of fuel. That can be confirmed by dropping fuel pressure or having the injector duty cycle over 90%.
    If it's on the rich side, then fuel needs to be removed via the MAF table. It needs to be scaled back to tell the computer that it's really not pulling in that much air and needs less fuel.
  12. #12 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    DHP sorry
  13. #13 Re: Abnormal amount of KR
    super low means nothing, stock should be 16 ish
  14. #14 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    I'm still learning someof this stuff sorry. but the timing is set to 5-7* I believe.
  15. #15 Re: Abnormal amount of KR
    Timing will be low if it's showing that much knock.
    Not to say this tooner doesnt know what he's doing, but I'd be concerned if he really set timing to that low of the number. That's just going to hurt the engine.
  16. #16 Re: Abnormal amount of KR
    DHP sorry
    id be happy to look at your bin you can email it, i use dhp myself.
  17. #17 Re: Abnormal amount of KR
    like zero lol
    when i was stock i had 8ยบ kr and showed like 5 degrees timing lol
  18. #18 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    I dont have the hardware or programs to get to it. sorry guys. It may just be a needle in a haystack
  19. #19 Re: Abnormal amount of KR
    your friend has it on his laptop. have him email it to you, you can email it to me. if i see some thing messed up i can fix it and send it back to you.
    then he re flashes the new bin. pretty painless. ive done it for many guys here.
  20. #20 Re: Abnormal amount of KR
    Mar 2016
    Colorado
    He swears up and down its not the tune haha, i'll see if i can get it. He also suggested my MAF is shot
  1. Least amount of drone
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2014, 11:20 AM
  2. Alarming Amount of KR?!?
    By bignose94015 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2014, 05:58 PM
  3. What amount of KR is acceptable?
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2013, 05:56 PM
  4. 97 Grandprix GT - Abnormal radio static
    By 98GPGT2D in forum Audio, Security & Visual Electronics
    Last Post: 01-15-2012, 06:21 PM
  5. 2001 GTP - Abnormal tire wear (cupping) due to struts?
    By zguy in forum General Tech Discussion
    Last Post: 01-09-2012, 10:35 PM
