Thread: Fitting?
Results 1 to 8 of 8
  1. #1 Fitting?
    SE Level Member james782004's Avatar
    Nov 2015
    Looking to see if parts from a newer say 05 or 06 will fit on my 97? Interior wise. I know engine and trans will. Thanks
    Sent from my SM-G920R4 using Tapatalk
  2. #2 Re: Fitting?
    Besides seats....no
    04 Comp G.
  3. #3 Re: Fitting?
    Nov 2015
    Perfect forgot 2 mention the seats ty!
  4. #4 Re: Fitting?
    Apr 2011
    Elk Rapids, Michigan
    Transmission isn't a direct swap. The internal wiring harness is different. The pin assignments are different.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  5. #5 Re: Fitting?
    Nov 2015
    If I were to take the engine and trans it wouldn't it be easier to take the a frame?
  6. #6 Re: Fitting?
    Apr 2011
    That's the GM recommend method of removing and replacing the engine and transmission assembly. Again, you can't just plug the 03 and newer transmission into your 97 to 02 engine harness. The electrical connector pin assignment on the 03 and new transmission is different.
  7. #7 Re: Fitting?
    Nov 2015
    Ahh I see what you are saying.
  8. #8 Re: Fitting?
    Nov 2015
    missouri
    ExLimey can I message you with some questions I have about differ cars
    Sent from my SM-N900T using Tapatalk
  1. Fitting an L36 HV3 into an L26
    By nik12937 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2014, 08:17 PM
  2. Fitting two ported T2's...
    By nik12937 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 11:24 PM
  3. A/C fitting cleaning
    By tdm571 in forum General Tech Discussion
    Last Post: 02-22-2011, 08:58 AM
  4. which fitting is which?????
    By chancinit666 in forum General Tech Discussion
    Last Post: 12-11-2010, 11:58 AM
  5. FPR vac fitting
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 11:50 PM
