Thread: cooling fan question
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 cooling fan question
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    On my 01 gtp the cooling system has been really odd. today i started the car for the first time in a few days to look at something else and both of the cooling fans were on.
    The engine was cold and they turned on as soon as the car did
    When are they supposed to come on? and could this be a faulty temp sensor??
  2. #2 Re: cooling fan question
    If the defrost was on, they do come on even when cold.
    But if that isnt the case, the temp sensor could be going bad.
  3. #3 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    Well it came on all the time so I changed it out with a brand new one
    The problem now is that it says the temperature is all the way up as soon as you start it......
    Wtf is going on???
  4. #4 Re: cooling fan question
    Bad new temp sensor.
  5. #5 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    It was a bad temp sensor and I got the "better brand" in there now and it works, but those fans still come on. What else could cause this?
  6. #6 Re: cooling fan question
    fans come on as soon as the car is fired up? thats the default when you unplug the sensor. both fans on all the time.
    you likely got a bad wire from the temp sensor to the fans. that harness gets baked in the heat of the exhaust pipe there, check the wires in the short harness to the temp sensor for cracks or bare wire showing.
  7. #7 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    Could it be the connector itself? I've heard of this happening on other cars
  8. #8 Re: cooling fan question
    anythings possible, but its send to the dash and pcm as per your scanner telling you the temp as well right?
    so that leaves a break between the plug and fans.
  9. #9 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    Well its not really getting the full voltage on the gauge and the pcm. I know the engine is way hotter than what it's saying
    It looks like where the wires go into the connector they have some bare wire and also look pretty cooked....
    I don't have my scanner right now but i will in a few days
  10. #10 Re: cooling fan question
    you need to replace that short harness off the temp sensor then. bare wires are dead wires.
    the exhaust is right there baking the crap out of it. put a fork in it....
  11. #11 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    I would change it just to check but this is the only one I can find : http://www.amazon.com/Standard-Motor...CAHERFGWNBNK3K
    and $16 feels like too much to just test around with when ill be going to the junk yard this Saturday.
  12. #12 Re: cooling fan question
    your fine till you hit the junk yard for another one. the fans are just on full time. heater may suck but it wont over heat.
  13. #13 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    So I got 2 new ones at my junk yard and neither of them worked. They were off old cars and they looked about the same as mine but they both let the fans come on.
    Does this mean the problem is farther down the cables?
  14. #14 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    They look like this
    And they connect to here
  15. #15 Re: cooling fan question
    Buffalo
    Lower left hand corner of the picture. Those wires. Open that connector. How's it look inside
  16. #16 Re: cooling fan question
    if the harness is the same style, same plugs. id look on the other side of that plug on the lim there for more damaged wires.
  17. #17 Re: cooling fan question
    your harness is un covered too on the fans, make sure those are all ok too.
  18. #18 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    Here's what the fan connector looks like
    The wires aren't bare and the inside of the connector looks okay too
    On the thing the wire also look fine
  19. #19 Re: cooling fan question
    Nov 2015
    Olive branch, MS
    Quote Originally Posted by ScottyDoggs View Post
    This is the other side
  20. #20 Re: cooling fan question
    follow that wire, see if you can find any damage.
    your on a mission now. when its not the simple things get a bit tougher.
    your heat and or a/c are off right? cause the ac turns the fans on, defroster should also make the fans turn on.
  1. Cooling Question
    By blackthunder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2014, 12:26 PM
  2. Question: Engine is cooling off to much on highway driving
    By michaelg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2012, 08:37 AM
  3. cooling system question
    By iluvbst in forum General Tech Discussion
    Last Post: 12-05-2010, 10:07 AM
  4. A/C not cooling
    By VolsFan in forum General Tech Discussion
    Last Post: 05-16-2010, 08:54 PM
  5. Cooling system question
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-13-2009, 08:24 PM
