Thread: Light Engine knock
Results 1 to 9 of 9
  1. #1 Light Engine knock
    Jan 2016
    Southwest Mn
    Ok guys, got a question for you..I have an 02 and it had a int light knocking noise that I thought was coming from the loose water pump that I but after replacing that the noise is still there..sounds like its coming from underneath by the torque converter or that area of the oil pan....don't think its coming from balancer....are the flexplates known to crack on these? only does it at idle..as soon as you come off idle the noise is gone....any help would be appreciated
  2. #2 Re: Light Engine knock
    They do crack but not very often. They tend to be louder than just a faint knock noise though, often the same pitch as a spun rod bearing.
    I'd maybe even try some trans fluid in the oil to see if it clears anything up that may be from a lifter making noise. Or drive it and see if the noise starts getting worse.
  3. #3 Re: Light Engine knock
    SE Level Member b4black's Avatar
    Oswego, IL
    They do crack often. They start out faint and get worse. Pull the inspection cover for the torque converter off. It's just two 10 mm bolts.
    This should help.
    http://www.grandprixforums.net/threa...g-sound-06gpgt
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  4. #4 Re: Light Engine knock
    Jan 2016
    Southwest Mn
    I did pull the inspection cover and looked but didnt see anything but it is hard to see, but thanks for the link..the more reading I did it sure sounds like the flexplate guess I'll just have to take a closer look...maybe seperate the t/c from it and try running it and see if noise is gone.
  5. #5 Re: Light Engine knock
    Jan 2016
    Southwest Mn
    The noise should go away if I seperate the t/c from the flexplate correct?
  6. #6 Re: Light Engine knock
    Oswego, IL
    Mine didn't. But without the TC spinning, I know the issue is not in the trans.
  7. #7 Re: Light Engine knock
    Jan 2016
    Southwest Mn
    Its got me worried. .only does it at idle..no noise after that
  8. #8 Re: Light Engine knock
    Oswego, IL
    That's pretty much what happened when my first flex plate went. Knocking at idle and a bad "buzz" sound when decelerating. I could see the cracks in the flexplate between the three windows. It was cracked all the way around once I got it removed.
    Now I'm getting the same rattling at idle only. I can't see any cracks, but I'm 90% sure it's a flex plate again.
  9. #9 Re: Light Engine knock
    Jan 2016
    Southwest Mn
    Yup..crawled under there today and looked a lil closer and saw a crack...flexplate it is
  1. Engine Knock
    By chrisangelly1981 in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 01:42 AM
  2. Need help engine knock??
    By thomasd2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2012, 04:34 PM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. knock sensor and airbag light
    By 08pontiacgxp in forum 5.3L V8 (LS4)
    Last Post: 09-25-2010, 11:26 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
