Thread: 2.6" or 2.7" pulley?
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
  1. #1 2.6" or 2.7" pulley?
    SE Level Member b4black's Avatar
    Oswego, IL
    Last summer I was running a 2.9" pulley on E85 and 24° timing with no knock. This summer I'd like to drop the pulley size and run less timing. I figure I need to go smaller than a 2.8"
    I read that anything smaller than 2.8" requires machining the snout. I've already ground the fins off. Is that enough to run a 2.7" or even 2.6"? At what point is belt slipping a problem?
    Thanks!
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  2. #2 Re: 2.6" or 2.7" pulley?
    Buffalo
    This is what I needed to do
    im using a 2.8 but with 8rib belt. No slip. But I'm anticipating it with my 2.6 so I have the prj belt wrap just in case.
    If you need to borrow the tool PM me here or on RGS if it ever comes back up !
  3. #3 Re: 2.6" or 2.7" pulley?
    Kemmerer, Wyoming
    I wouldn't worry about belt slip unless you start seeing signs of it. if you do have belt slip, you can get a wbodystore belt wrap kit for both gen 3 or 5.
  4. #4 Re: 2.6" or 2.7" pulley?
    Donating Users timboku's Avatar
    Montgomery, IL
    You need to machine snout for a 2.7, and without a belt wrap your getting belt slip even on a 2.9, it's the nature of it..
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: 2.6" or 2.7" pulley?
    Buffalo
    Depends on what size belt tho. You can't say sure until you know his set up / and if he currently has a 2.9 and no slip - well there ya go!
  6. #6 Re: 2.6" or 2.7" pulley?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Get a belt wrap for assurance. They look cool too.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  7. #7 Re: 2.6" or 2.7" pulley?
    Oswego, IL
    I've been running the 2.9" pulley for a couple of years with no slip. I'd rather not use the belt wrap kit.
    Will the 2.7" fit if I just grind down the ribs on the snout?
  8. #8 Re: 2.6" or 2.7" pulley?
    2.8 and timing. i know 2.8 fits stock snout.
    edit didnt see your already at 24* DAMN
  9. #9 Re: 2.6" or 2.7" pulley?
    Oswego, IL
    Let me try this from another angle. Anybody have a 2.7" or 2.6" ZZP or Intense pulley that they could measure the ID of the backside for me?
  10. #10 Re: 2.6" or 2.7" pulley?
    Buffalo
    I have a 2.6 on the shelf at home
  11. #11 Re: 2.6" or 2.7" pulley?
    Belt wrap isn't needed and is laughable.
    I didn't see, is this a GenIII or GenV car?
    Either way, I'd run a 2.6" and back the timing a smidge. I remember reading somewhere anything north of 22-23 isn't worth the aggressive stand; I mean, unless you just kept running it up until it started knocking. What's the WOT AFR reading at? I'd mess with that more than anything.
  12. #12 Re: 2.6" or 2.7" pulley?
    I'd almost think once the blower is spinning that fast it won't make anymore power, seen it before where trying to add boost doesnt increase power because now the air is even hotter and blower is far past it's efficiency range.
  13. #13 Re: 2.6" or 2.7" pulley?
    Buffalo
    Quick. Someone que in slo with his maps and charts
  14. #14 Re: 2.6" or 2.7" pulley?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    timing is the key to power. more timing with the biggest pulley you can run.
  15. #15 Re: 2.6" or 2.7" pulley?
    May 2008
    Schuyler, NE
    That is not correct.
  16. #16 Re: 2.6" or 2.7" pulley?
    Buffalo
    2.25" inner diameter
  17. #17 Re: 2.6" or 2.7" pulley?
    Oswego, IL
    Thanks! I just measured the snout and it's just a touch over 2.25". Maybe 1/32" over. I bet (hope) the 2.7 would work with just the fins removed. For me, the 2.6 was probably pushing it anyway.
  18. #18 Re: 2.6" or 2.7" pulley?
    May 2008
    Schuyler, NE
    Smoothflow pullies can be run down to a 2.7 without machining the snout. I don't know about any smaller though. I do know that there is not much room left between the snout and the pulley though.
  19. #19 Re: 2.6" or 2.7" pulley?
    Man, you've only got an open cone with a 2.7"?
    Major noob. Hope it pops.
  20. #20 Re: 2.6" or 2.7" pulley?
    May 2008
    Schuyler, NE
    That's just how I roll dude. When in doubt, more boost.
  1. 3.5 pulley, TB Spacer, PLOG, other "go fast" goodies
    By GTPlzz in forum Wanted To Buy - Parts
    Last Post: 02-13-2014, 04:27 PM
  2. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
