Thread: Help?
Results 1 to 16 of 16
  1. #1 Help?
    SE Level Member duswickware's Avatar
    Jan 2014
    mansfield, ohio
    While I was cleaning the threads on the block for my head bolts, the tap went too deep and fell off in the block. Top far right hole in the front. 98 gtp, any suggestions getting it out, not sure if it was a coolant port or oil.
  2. #2 Re: Help?
    Jan 2014
    mansfield, ohio
    I'm assuming I can drop the oil pan and hope it fell down there somewhere.
  3. #3 Re: Help?
    its in the coolant area of the block, the only way to get it out is via a freeze plug. even then you may not get it out.
    dont see why it cant stay in there.
  4. #4 Re: Help?
    Jan 2014
    mansfield, ohio
    If it can stay in there I'm all for it lol. Just don't wanna f*** something up when I finally gets the thing back together.
  5. #5 Re: Help?
    is the engine on a stand? or in the car? in the car still f it for sure.
  6. #6 Re: Help?
    Jan 2014
    mansfield, ohio
    Still in car, looks like I'm gonna buy another tap lol. Thanks for the help Scotty.
  7. #7 Re: Help?
    no need to buy a tap. take a old head bolt, cut a groove up the threads with a grinder, run the bolt in the holes.
  8. #8 Re: Help?
    Buffalo
    ¯\_(ツ)_/¯
  9. #9 Re: Help?
    Jan 2014
    mansfield, ohio
    Well dam! Thanks again.
  10. #10 Re: Help?
    google diy thread chaser. i did two grooves, some do one.
  11. #11 Re: Help?
    Jan 2014
    mansfield, ohio
    I did two, worked like a charm.
  12. #12 Re: Help?
    Buffalo
    I just find it funny when I suggested that. It was considered dumb
  13. #13 Re: Help?
    Quote Originally Posted by CrazyGuy03 View Post
    depends on what part was called dumb? making the diy chaser, or chasing the threads at all? saw a lot of threads saying to clear the threads. and the diy chaser works by golly lol
  14. #14 Re: Help?
    Buffalo
    It help tremendously doing my head studs.
  15. #15 Re: Help?
    Buffalo
    When I mentioned the fact I kept spare bolts and cut em for thread chasers
  16. #16 Re: Help?
    it does. dont know what dummy was dis ing you. but hes off kilter.
