Thread: car likes to choke/dog down sometimes
Results 1 to 12 of 12
  1. #1 car likes to choke/dog down sometimes
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    Every once and awhile my 2005 grand prix comp g likes to not want to accelerate and feels like it's misfiring. It will do this from start up until it's stopped. Most of the time if I shut it off it will restart and be just fine. I have been just dealing with it for a while but recently it's become more frequent and back to back one time and thst bothers me. (Scan Guage doesn't read misfires)
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  2. #2 Re: car likes to choke/dog down sometimes
    St. Louis
    Clean the throttle body lately? If not I'd start there.
  3. #3 Re: car likes to choke/dog down sometimes
    Nov 2010
    Maryville, MO
    Yeah I already tried that. Also changed the icm, had a spare one laying around
  4. #4 Re: car likes to choke/dog down sometimes
    Get a scanner than can read what you want to see.
    We can't just guess at this stuff, we can't see this issue infront of us.
    Figure out if it's really a misfire or something else, the scanner is the best bet to diag any issue like this. Knowing what is happening in real time is the only way to figure this out.
  5. #5 Re: car likes to choke/dog down sometimes
    GXP Level Member
    Mar 2015
    Tomball
    Does it just lay over and seems to have no power? Watch the timing when it does this.
    Jeff
  6. #6 Re: car likes to choke/dog down sometimes
    Nov 2010
    Maryville, MO
    I'll watch the ign timing next time it happens on my scan gauge. Any other parameters I should watch?
  7. #7 Re: car likes to choke/dog down sometimes
    GXP Level Member
    Mar 2015
    Tomball
    KR, Map and MAF
  8. #8 Re: car likes to choke/dog down sometimes
    It's useless to scan those if he doesnt even know what the numbers will mean.
    Only clear cut answer would come if the MAP just whacked out and starts spraying out numbers that arent really happening at the time or the MAF drops out.
    I'd still get a better scanner that can possible see real time misfire to watch every cylinder to determine an electrical/spark issue.
  9. #9 Re: car likes to choke/dog down sometimes
    Nov 2010
    Maryville, MO
    Yeah i dont know what numbers should be coming out of maf/map sensors. i have been watching the ig timing and nothing out of the ordinary seems to be shown when its choking. I watched for misfires when it was occurring and a total of 2 on cylinder 3 showed up (drove several blocks). so im betting its not spark/fuel related
    // 2005 Comp G
  10. #10 Re: car likes to choke/dog down sometimes
    GXP Level Member
    Mar 2015
    Tomball
    Mine did it this morning and when I am usually showing about 35-40* of timing it dropped to 20 and I knew it was showing KR and usually it shows about 15* when it does that. I was still rolling and shut the car off and restarted it and the timing came back to where it should be drove the rest of the way to work and it was fine. I have not been able to look at timing AND KR at the same time on mine so I either have one or the other up.
    Jeff
  11. #11 Re: car likes to choke/dog down sometimes
    Nov 2010
    Maryville, MO
    Sounds exactly like mine, I'm watching my timing but haven't noticed that much of a change
  12. #12 Re: car likes to choke/dog down sometimes
    GXP Level Member
    Mar 2015
    Tomball
    Select Knock Retard and watch that. You may have better luck than me and be able to watch timing and Knock Retard on the App. Mine seems to have to look at different protocols for KR and Timing. Make sure to select gauges that show minimum and maximum values. Sometimes things happen that you can't really watch but will be displayed as high or low. When I first got my car I would have times where it would crater the timing at -15* (15* ATDC) and the car would really fall flat, I doubt you are seeing that. You won't really have timing values less that 15* unless you have it at a hot Idle in park or neutral and it will be about 3-8*, or sometimes in gear it might drop to 5* when decelerating but you will only be worried about accelerating. Just reset the min/max when you need to. Mine happens so infrequently that it's hard to catch unless you have the app up all the time. I have only one DHP log file where I catch it happening.
    Jeff
  1. am i the only one who likes the Aztec
    By 04lss in forum Off Topic Discussion
    Last Post: 09-24-2015, 03:19 PM
  2. who likes em
    By BoostJunki3 in forum Tires & Wheels
    Last Post: 09-23-2010, 04:34 PM
  3. who likes gunsss....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 06-02-2010, 06:05 AM
  4. who likes ATV's / Jet Ski's ??
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 04-29-2010, 09:35 PM
