Thread: intermittent Knocking sound 06gpgt
Page 5 of 5 FirstFirst ... 345
Results 81 to 85 of 85
  1. #81 Re: intermittent Knocking sound 06gpgt
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I don't want to be a downer here, and hope it is just a flex plate, but that video is the exact sound my gtp made. I had spun 2 rod bearings. It would go away when climbing in rpm, and knock coming down off revs. Good thing is you said you saw nothing in your oil change, aluminum bearing material most likely would be in there if it was a bearing.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  2. #82 Re: intermittent Knocking sound 06gpgt
    Jan 2016
    michigan
    Did your knock dissipate after idling or just not be there?
  3. #83 Re: intermittent Knocking sound 06gpgt
    redneck tennessee
    It was only quiet on a cold crank, once warm I could always get it to knock coming down off a rev.
  4. #84 Re: intermittent Knocking sound 06gpgt
    Jan 2016
    michigan
    Yeah mine never does it when cold and does it intermittently when warm. Also noticed it changes with what gear it's in and goes away in between gears. Easiest to do that is in between park and reverse. Completely gone then.
  5. #85 Re: intermittent Knocking sound 06gpgt
    Jan 2016
    michigan
    So as crazy as this sounds no one has been able to figure the out what was causing the noise and on top of that, the warm weather we have been having it is now gone and havent heard it since it got warmer out. coincidence? Strangest sh*t ever.
  1. Knocking/clanking sound
    By Kellson in forum General Grand Prix Discussion
    Last Post: 04-20-2014, 09:41 PM
  2. Knocking sound..
    By Jordin in forum Brakes/Suspension/Chassis
    Last Post: 02-29-2012, 09:52 PM
  3. knocking sound
    By casperyaj in forum General Tech Discussion
    Last Post: 03-27-2011, 08:43 PM
  4. knocking sound
    By scott1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 08:46 AM
  5. knocking sound
    By kenneth74gt in forum General Tech Discussion
    Last Post: 08-24-2010, 04:13 AM
