Thread: Car won't start after repair
Results 1 to 20 of 21
  1. #1 Car won't start after repair
    Jan 2016
    Tucson, AZ
    Good morning, new user, first post.
    I replaced the valve cover gaskets on my '06 3800 SC GP. After hooking everything back up the car ran rough for about a minute then shut down. It would not turn over at all. After a few minutes it will now turn over once but not start. I triple checked my spark plug wires and they are correct. One caveat - I accidentally broke a hose (very brittle) and I'm not even sure where it was supposed to connect to. I can't find a male piece or nipple anywhere on the firewall side of the engine. I'll try to add a picture if I can. (This is my first forum membership of any kind. Still learning the technical side of the site).
    Any help would be appreciated.
  2. #2 Re: Car won't start after repair
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Willing to bet that hose has something to do with it.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: Car won't start after repair
    post a pic of broken part. host the pic off site. aka pb, image shack, what have you.
  4. #4 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    Thank you for the tip. Couldn't upload it to the site.
    http://imageshack.com/a/img633/5186/ksLrwL.jpg
  5. #5 Re: Car won't start after repair
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    are you sure nothing fell into the head while you changed the VC gasket? could have gone into the engine.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  6. #6 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    I'm having trouble with the video i took showing where the part connects. It comes off a T that is under the supercharger. The other part of the T goes to the front and hooks up to an O2 sensor maybe? and the part i broke goes to the firewall side. there was about 3 more inches to that part. So it was about 10-11" total from the T.
  7. #7 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    I don't think so. At least I really hope not.
  8. #8 Re: Car won't start after repair
    Quote Originally Posted by Professor X View Post
    this is a vacuum line. its needed or your'll have a vac leak, will make the car run poorly, stall out...wont keep it from cranking tho. what year is your car?
  9. #9 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    That's what I figured but I can't figure out where it goes.
  10. #10 Re: Car won't start after repair
    Sep 2014
    Richmond Virginia
    Did you remove the bracket that holds the coils to do the change?
    If so have you checked all of you grounds and connections?
    Battery have a good charge?
  11. #11 Re: Car won't start after repair
    under the sc snout on the side of the lim is a T, one side to the fpr, the other to the map sensor.
    your lines should be close to this.
  12. #12 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    yes! It comes off the T under the snout. so it must go to the MAP sensor, according to this diagram. Now I need to find that. But at least i'm on the right path. Thank you!
  13. #13 Re: Car won't start after repair
    on the back you have two sensors that look the same. it goes to one, the other gets nothing to it but its plug.
    like this.
  14. #14 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    Got it. so it doesn't matter which one I connect to?
  15. #15 Re: Car won't start after repair
    It does.
    One is a MAP sensor, the other is a baro sensor.
    I think only one has a nipple on the bottom, and the line can only be so long so it's kinda easy to figure out what one it's for.
  16. #16 Re: Car won't start after repair
    GXP Level Member
    Mar 2015
    Tomball
    The MAP is closest to the Drivers side. Both sensors are the same part number.
    Jeff
  17. #17 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    Quote Originally Posted by J57ltr View Post
    Jeff
    Thank you - I couldn't find an original part. Picked up a piece of more flexible hose that will serve as a patch of sorts. It fits over the hose on either end. Also, both have a nipple so I picked up a cap for the other one. Thank you all for the info and help. I would have been stuck for a long time today.
    Thanks again.
  18. #18 Re: Car won't start after repair
    un cap the other one. its supposed to be open, its a baro sensor. what ever the f that is lol
  19. #19 Re: Car won't start after repair
    GXP Level Member
    Mar 2015
    Tomball
    Yes, as Scotty said it is open to atmosphere so just leave it. Also use some small ty wraps to hold it on the tubing for the MAP sensor. Later after it's all sorted out you can replace all the hard lines with flexible line if you want. They will become more brittle with age. I had the one under the snout snap the other day. Came out for lunch started the car and it started to lope. Then the traction control and ABS turned off and it went into reduced power mode. Reduced power mode is bad. If you ever see this get it shut off as quickly as possible as it sets the engine at 15* AFTER TDC and full rich and you can burn up the cat in short order if left running in this condition for any time. It also locks you out of the throttle once you come to a stop.
    Jeff
  20. #20 Re: Car won't start after repair
    Jan 2016
    Tucson, AZ
    Quote Originally Posted by ScottyDoggs View Post
    Thank you SD. Saved me another head scratching moment
  1. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  2. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  3. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  4. 1990 3.1 lit hard start/ no start. fuel pressure prob
    By wadd in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2015, 07:22 AM
  5. 1998 GTP supercharger repair kits repair cost
    By SpecialK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2015, 10:49 AM
