Thread: 98 gtp no fuel no spark
Results 1 to 7 of 7
  1. #1 98 gtp no fuel no spark
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    Got gas this morning car wouldn't start. .no fuel pressure so I replaced the pump. .nothing. .the relays and fuses are all good.i turn the key forward all the lights come on the dash,fuel pump doesn't energize and I checked for spark while cranking. I noticed the security light was flashing. .please help ASAP please
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #2 Re: 98 gtp no fuel no spark
    Do a security relearn??
  3. #3 Re: 98 gtp no fuel no spark
    Topeka, ks
    How
  4. #4 Re: 98 gtp no fuel no spark
    when ever i had to do a relearn the car dont crank at all. aka dead key. and that was only after flashing a new pcm to my car.
    how to do a relearn, cant hurt to try. http://www.3800pro.com/forum/pcms-tu...procedure.html
  5. #5 Re: 98 gtp no fuel no spark
    Topeka, ks
    Quote Originally Posted by ScottyDoggs View Post
    Do I have to use that procedure or can I do this with a snap on solus ultra scanner? ?
  6. #6 Re: 98 gtp no fuel no spark
    Topeka, ks
    OK thanks forgot to mention not sure this will matter but I installed a remote start keyless entry about a month ago, it's not my first time doing a remote start n have never encountered any problems after s remote start install. .I took the remote start module clear out today also nothing changed same crank no spark or gas
  7. #7 Re: 98 gtp no fuel no spark
    that how to learns the key. like i said, when i needed to do that it was only after flashing a new pcm to my car.
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. Won't start, has fuel and spark
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2014, 05:32 PM
  3. have spark and fuel pressure. no start
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2012, 12:26 PM
  4. Not starting- no spark, no fuel pump
    By craigztoyz in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-17-2009, 01:24 PM
  5. HELP car won't start, got fuel, got spark, got air?
    By bezemom in forum General Tech Discussion
    Last Post: 05-29-2009, 02:19 PM
