Thread: Cooling fan
Results 1 to 15 of 15
  1. #1 Cooling fan
    Jul 2015
    USA
    Trying to change my cooling fan and after I got it out and went to replace it with a new fan, the plug-ins for the fans are in different spots. I'll attach a photo of the fans my car had, my question is are these original fans some custom thing?
  2. #2 Re: Cooling fan
    Jul 2015
    USA
    Here's the attachment photo of fan the car had.
  3. #3 Re: Cooling fan
    Aug 2011
    'Merica
    I see no photos
  4. #4 Re: Cooling fan
    Jul 2015
    USA
    Sent from my XT1254 using Tapatalk
  5. #5 Re: Cooling fan
    http://www.ebay.com/itm/99-03-GRAND-...-/170484612034 looks like you need to take the wire harness off the fans and put it on the other set.
  6. #6 Re: Cooling fan
    Jul 2015
    USA
    The wire harness is too short...
  7. #7 Re: Cooling fan
    Jul 2015
    USA
    Is it some goofy fan my car came with? I have no idea why the previous owner wouldn't just get one that at least goes back in like an OEM.
  8. #8 Re: Cooling fan
    post a pic of the two side by side. do the plugs from the harness fit the plugs?
  9. #9 Re: Cooling fan
    Jul 2015
    USA
    The plugs fit but the harness is too short.
  10. #10 Re: Cooling fan
    you can always cut the wires and make them longer.
  11. #11 Re: Cooling fan
    Jul 2015
    USA
    It's just odd that the auto parts store had them flipped sides, I ordered another set thinking it was a manufacturing issue but there is also the number 1042825g on the original one. I returned the other fans.
  12. #12 Re: Cooling fan
    Jul 2015
    USA
    I might just have to make them longer but that just seems ridiculous, this should not be much of a project.
  13. #13 Re: Cooling fan
    just make sure you solder the new wire in and use shrink tubes to seal it from weather. best way to splice wire.
  14. #14 Re: Cooling fan
    Jul 2015
    USA
    Ok, this is probably a stupid question but the two motors are different size, (one ac fan and one regular) won't it then run on the AC fan all the time and henceforth burn out quicker?
  15. #15 Re: Cooling fan
    both fans turn on with the ac. both of my fans turn on for temp. never seen just one work ever.
    wire em up and dont over think things.
  1. Cooling System Help
    By DrKavorkien in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2012, 01:10 AM
  2. Air in Cooling System?
    By tuchek in forum General Tech Discussion
    Last Post: 02-06-2012, 07:04 PM
  3. cooling?
    By jerrysalley in forum General Tech Discussion
    Last Post: 08-18-2010, 11:36 AM
  4. A/C not cooling
    By VolsFan in forum General Tech Discussion
    Last Post: 05-16-2010, 08:54 PM
  5. Cooling
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 07:30 PM
