Thread: Next Mod and KR reduction Ideas
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 88
  1. #21 Re: Next Mod and KR reduction Ideas
    Dec 2013
    laporte mn
    I ran 20° of timing at 12.0 afr wot with 0 kr all the way through the shifts on 91 octane pump gas
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  2. #22 Re: Next Mod and KR reduction Ideas
    SE Level Member MeanGrn99GTP's Avatar
    Dec 2015
    Saint Paul, MN
    Quote Originally Posted by gambler87 View Post
    MeanGrn99GTP I ran a 3.6 setup on a gen v on my 04 with 1.84 yt rr stock springs, sd headers, 104s, and 180° thermostat.
    If u would like I have DHP power tuner and I run to the cities alot if u want I can either set up up with my old 3.6 tune or I can run some custom tuning for u
    That would be great!
    I just bought a stock TB so I will try to swap them today or tomorrow. I got a used M90 and LIM with it too for $125. I am going to port it and rebuild it.
  3. #23 Re: Next Mod and KR reduction Ideas
    Dec 2013
    laporte mn
    Nice. Pm me ur cellphone number
  4. #24 Re: Next Mod and KR reduction Ideas
    Dec 2015
    Saint Paul, MN
    https://youtu.be/ObxE9HL0rDw
    I installed the stock Throttle body. Here is a roll on clip up to about 70 mph. KR and Ign. Adv. values.
  5. #25 Re: Next Mod and KR reduction Ideas
    Kemmerer, Wyoming
    Time to pulley up
  6. #26 Re: Next Mod and KR reduction Ideas
    Dec 2015
    Saint Paul, MN
    I'm at a 3.8"
  7. #27 Re: Next Mod and KR reduction Ideas
    Time to put a stock throttle body back on it or get an actual tune.
    160* doesn't matter, proven they actually run 10-15* hotter than the listed temp. My 160* cars always sat around 175*~, which is enough to have the knock sensors report (anything less than 169* I don't think they give a sh1t).
    As for the rest of the mods. TB spacer is worthless, throw it out. Iridium plugs? Nope. Chuck them. Get cheapo 104 copper plugs.
    Rockers, headers, tune, and a 3.4" should be just fine knock free with at least an 04+ timing table.
  8. #28 Re: Next Mod and KR reduction Ideas
    Quote Originally Posted by blueguy View Post
    not always, i had 4º kr after these exact mods were installed. being i have a tuner i was able to tune it out. 04- 05 timing its to high really. back to stock worked best with maf tuning.
  9. #29 Re: Next Mod and KR reduction Ideas
    Kemmerer, Wyoming
    I had more kr when I was running the iridium plugs, so X2 on the copper tip plugs.
  10. #30 Re: Next Mod and KR reduction Ideas
    Quote Originally Posted by MeanGrn99GTP View Post
  11. #31 Re: Next Mod and KR reduction Ideas
    Sep 2014
    Worcester, MA
    What gasoline are you running? E-10? E-15? Is it brand name, or from the crappy gas station that sells really cheap (but really old) gas?
  12. #32 Re: Next Mod and KR reduction Ideas
    Everything in MN is up to 10% ethanol.
  13. #33 Re: Next Mod and KR reduction Ideas
    Dec 2015
    Saint Paul, MN
    BP 93 octane. 10% ethonol.
    I just bought some copper 104s. I will get them in today or tomorrow and video another pull.
    I just replaced the o2 and I am getting an o2 slow response code now. I just figured it was the original with 93,000mi it wouldn't hurt to put a new one on. This is a denzo.
    What o2 does everyone else run?
  14. #34 Re: Next Mod and KR reduction Ideas
    Kemmerer, Wyoming
    ac delco from amazon. this is the upstream.
    http://www.amazon.com/gp/product/B00...ilpage_o09_s00
    I shop on amazon more often because I am a prime member and get free shipping a lot.
  15. #35 Re: Next Mod and KR reduction Ideas
    Is it a 1133 code??? All that is saying is that it once the car reaches closed loop mode that it didn't switch between rich and lean enough times in a given amount of time. I think GM cars is 90 seconds is how long it runs the test, figure it wants to see 60 switches but it saw 55 or 58 more than one time it will set the code. I dealt with it when I did headers and after a few times it stopped popping up.
    If so, just clear it. It's a pretty common code anytime you have headers or aftermarket manifolds to the car.
  16. #36 Re: Next Mod and KR reduction Ideas
    Denso and delco are just fine, both are oem. You wouldn't want to run a bosch though.
  17. #37 Re: Next Mod and KR reduction Ideas
    Good thing you're paying attention, Cam.
    Way to save the day.
  18. #38 Re: Next Mod and KR reduction Ideas
    Somebody has to do it.
  19. #39 Re: Next Mod and KR reduction Ideas
    Dec 2015
    Saint Paul, MN
    P0133
    I did not get this code once with the original o2. It pops up everyday now since the new Denso.
  20. #40 Re: Next Mod and KR reduction Ideas
    I'd return it as faulty and get another then.
  1. Weight reduction
    By chadh8806 in forum General Tech Discussion
    Last Post: 12-26-2015, 08:00 AM
  2. Need more weight reduction ideas...
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 08-10-2014, 09:26 AM
  3. Torque reduction?
    By Pure2sin in forum PCM Tuning
    Last Post: 11-14-2011, 04:17 PM
  4. Weight reduction
    By Clar2478 in forum General Tech Discussion
    Last Post: 01-11-2011, 06:01 PM
  5. Weight Reduction Tips
    By Quicklynx in forum General Tech Discussion
    Last Post: 02-07-2009, 11:11 AM
