So I'm getting ready to burn the car to the ground. Here's why.
A few years ago I put on a 3" exhaust with a converter. No big deal. Normally I don't run a cat but I did anyways to keep the sound down on the 3800 sounding like a turd.
Last fall I put on 105 valve springs, modified retainers, locks, etc. Figured I'd replace the seals while I was there. So I got a set from ZZP. Put them on. everything seemed fine.
Had some issues at the track last week and so I gutted the cat converter. Lost 2 psi and such but everything else was fine until a few days later. Then I noticed puffs of blue smoke out the exhaust when I was idling and then gave it gas to go.
Pull the front and rear valve covers and 3 out of the 6 exhaust seals popped off the valve guides. I had a brand new set (brown?) that I got from the gasket kit from the other turd I'm working on.
Replaced all 6 of the exhaust seals. Buttoned it back up. (this was Saturday). Everything was fine until today.
Sitting at a light on the way home from work I give it some gas and look out the rear view mirror and no ****.. nice puff of smoke.
What would cause the seals to pop off again? I shouldn't have touched them when I did the valve springs but since they were cheap I figured I'd do them. Now I'm working on tearing this POS again a 3rd time to figure out why it's doing it.
Any ideas?
